DPF-R+ or DPF-R and SCT Tune - Ford Powerstroke Diesel Forum
post #1 of 16 Old 08-24-2013, 09:14 AM Thread Starter
I'm looking at doing away with my DPF and EGR and I need a tuner to program it. Has anyone had good luck with the DPF-R tuner from Gearboxz?
If so should I go with the DPF-R+ or just stack the DPF-R with another tuner (I was thinking SCT)
Can someone help me out? I really don't have over $1,000 to dump into a tuner like the Spartan or the Mini-maxx.
Thank you.
2008 F-350 6.4L SRW, SuperCab, Stock.... For now!
Purchased 7/24/2013!!
JamieK913 is offline
post #2 of 16 Old 08-24-2013, 09:19 AM
WoodBoy's Avatar
You cant stack with a programmer like sct. It has to be a tuner like Banks or edge juice. And if you are going to do that go with the regular dpf-r because I am pretty sure that if you want to stack the dpf-r+ you have to put it into stock power mode because you cant run the 70hp with other power tuning
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #3 of 16 Old 08-24-2013, 09:22 AM Thread Starter
Well that helps a little, any opinions on the Edge juice? I'm not looking to break a dyno or anything just get some good mpg and a little power boost.
Any advice on the DPF-R? as long as it doesn't throw codes I guess it does what it's supposed to.
post #4 of 16 Old 08-24-2013, 09:24 AM
WoodBoy's Avatar
I have seen people and had a buddy that run the dpf-r (not the plus) that he didn't have a lick of problems with. He ended up taking it off and putting a Spartan on because he wanted more power so he done that but like I said it done everything just fine. As for edge, I think their products are okay, and even banks products are pretty good
WoodBoy is offline
post #5 of 16 Old 08-24-2013, 09:31 AM Thread Starter
Cool, thanks man. I may be followed down the same route but this will do for now.
post #6 of 16 Old 08-24-2013, 10:48 AM
06superduty3997's Avatar
The DPF-R is a great tuner to run as a stand in until,you upgrade to a more powerful tuner. I have an DPF-R tuner that im selling if your interested.
2008 F-350 FX4 CCLB 6.4 Powerstroke
SCT Livewire With RCD Tunes. Magnaflow 5" Straight Pipe Exhaust with an 6 inch tip
Airaid drop in filter with a modded stock box. Halo/LED headlights, LED Mirror, Dually Fender Lights.
2.5 leveling kit Soon to Come,
Road Armor Front Bumper with Pre Runner Bar.
AF 19.5 wheels black
LED D2s and light bar
06superduty3997 is offline
post #7 of 16 Old 09-25-2013, 11:36 AM
I'm running a gearbox dpf-r 4.0 on just the dpf delete setting and have an sct 3015 stacked on it and it's running just fine.... I put the gearbox on first and then downloaded the sct on the performance tune and it's still running strong!
Bknight24 is offline
post #8 of 16 Old 09-26-2013, 10:47 AM
soundmandave21's Avatar
I do not see any reason why you could not stack an SCT programmer on top of a dpf-r performing delete only functions. You just have to make sure that if you are running the 70hp version of the gearboxZ, you do not load the 70hp portion of the tune. Just the dpf/egr delete portions.
1997 4x4 F-250 Xcab LB, ChildSeat
soundmandave21 is offline
post #9 of 16 Old 09-26-2013, 11:42 AM
i have a SCT 9625OR race tuner for sale if you want. that way you can load custom tunes if you want as well as not have to worry about the stacking deal.pm me for price
SOOTIE is offline
post #10 of 16 Old 09-26-2013, 02:28 PM
WoodBoy's Avatar
Hmmm... maybe I stand corrected.
I thought I read where gearbox stated that it would only run with inline pieces like the edge juice and banks
WoodBoy is offline
