EGR Delete Kit arrived & going in this weekend - Ford Powerstroke Diesel Forum
post #1 of 26 Old 08-23-2013, 05:42 AM Thread Starter
mikemass's Avatar
So I order the Flo-Pro full EGR delete kit with Intake Elbow from Rudy's via Ebay. Plan on doing job this weekend. I am anticipating that I may need to replace plastic Y-pipe as many here have said they break easily. I also am not sure if I have the upgraded upper coolant hose. So once that comes off I will see if it is the new (double O-ring White) version. Other than these 2 parts which may require a trip to the parts counter, is their anything else I may unexpectedly need to buy?
If I do need to replace parts, this will probably set me back a few days as tomorrow is Saturday and doubt Dealership has these in stock. Plus I could also save some coin by ordering on line.
Any last minute tips before I dive in? Gotta say, I'm a little nervous. I mean the experienced guys say it's a 5-6 hour job and I'm sure I will run into the unexpected. So just looking for where I may run into an elevated volume on the "curse - o - meter"..
Thanks in advance. I never would even attempt this job without all the information and advice I have gathered on this site.
2008 F-250 FX4 Crew Cab
DPF Delete 4" Straight pipe
Flo-Pro EGR delete w/ intake elbow
Gear Box Z DPF-R + with Economy Tune
78k miles as of April 2016
mikemass is offline
post #2 of 26 Old 08-23-2013, 06:09 AM
superduty6.4's Avatar
May as well do a coolant flush as well since you will have all the coolant drained anyways. Probably change thermostats as well.
08 F350 JOB 1
H&S MINI MAXX HD300 W/S1M
SINISTER EGR/COOLER DELETE
6000K BEAMERS HID HEAD & FOGLIGHTS
KMC XD WHEELS W/NITTO TRAIL GRAPPLERS
2.5" LEVELING KIT
DIESELSITE COOLANT FILTER
ROTELLA EC-1 RATED COOLANT
5" DP BACK FLO-PRO EXHAUST
FLO-PRO CAC PIPE & INTAKE ELBOW
CCV MOD
AIR LIFT 5000LB AIR BAGS W/ONBOARD COMPRESSOR
AFE CAI
PMF TRACTION BARS
superduty6.4 is offline
post #3 of 26 Old 08-23-2013, 06:29 AM Thread Starter
mikemass's Avatar
I've been losing so much coolant due to these damn EGR coolers over the last 12 months that it's like I've been doing coolant flushes. I mean no joke. I add about 1 gallon every 500 miles. It just disappears. Sure it's an internal cooler leak. Which is why I'm getting rid of the coolers.
mikemass is offline
post #4 of 26 Old 08-23-2013, 06:32 AM
WOW that's alot of coolant. Hopefully this solves your issue.
08 F350 JOB 1
2.5" LEVELING KIT
CCV MOD
AFE CAI
PMF TRACTION BARS
post #5 of 26 Old 08-23-2013, 08:04 AM Thread Starter
mikemass's Avatar
yeah. tell me about it. It's not showing up anywhere else either. No stains on the DeGas bottle. No external leaks. It's got to be leaking internally and going out the exhast.
mikemass is offline
post #6 of 26 Old 08-23-2013, 08:50 AM
DirtyDiesel's Avatar
Quoted: 3 Post(s)
Fwiw, go ahead and remove the left ft tire and fender liner. It makes removing the lower cooler much easier.
Brett
'08 Ford F-350 Powerstroke Lariet 4x4
SPARTAN Tuner, Flo-Pro 5" Exhaust 6" Tip, Deleted, S&B Intake, B&W Hitch, 2.5" Leveling kit, Custom Rear Traction Bars, 20x12 FUEL NUTZ, 33x12.5 Toyo MT's, PIONEER Screen, 3500W of ORION amps, Sundown SD3 10" subs, Blacked out Headlights, Retro LED bulbs, Recon Mirror Lights
DirtyDiesel is offline
post #7 of 26 Old 08-23-2013, 10:05 AM Thread Starter
mikemass's Avatar
will do that with the driver tire. Thanks
Hey. another dumb question. But why do I have to drain the coolant? Can't I just pop off the coolant lines and quickly get the coolant plugs on there? Or is that unrealistic that I can do that w/o making a huge mess?
mikemass is offline
post #8 of 26 Old 08-23-2013, 12:02 PM
You'll probably end up making a huge mess plus you said you were removing the rad hoses to check for the dual o-rings. Just be cleaner to drain it first.
08 F350 JOB 1
2.5" LEVELING KIT
CCV MOD
AFE CAI
PMF TRACTION BARS
post #9 of 26 Old 08-23-2013, 05:40 PM Thread Starter
mikemass's Avatar
Good point. I just sprayed down all the nasty looking bolts with some PB Blaster. Getting a good night sleep tonight as getting started early.
mikemass is offline
post #10 of 26 Old 08-23-2013, 06:25 PM
I find beer helps me stay on task
08 F350 JOB 1
2.5" LEVELING KIT
CCV MOD
AFE CAI
PMF TRACTION BARS
