power steering pump whining after lift - Ford Powerstroke Diesel Forum
post #1 of 9 Old 08-19-2013, 10:22 AM Thread Starter
countryboy73703's Avatar
Quoted: 2 Post(s)
installed a 3" front and 2" rear lift last week, didn't really mess up my alignment.. maybe a hair and then I had to make the steering wheel straight again, but everything is fix except the axle being shifted to the passenger side one inch, which I'm waiting for the Adjustable track bar to fix...
The problem is that now my Power steering pump is whining, even while going straight, it's not real loud but you can def hear it especially when you get the RPM's up. And now when I turn the wheel to the left, my ABS light comes on, and then when I straighten it back out or turn to the right, the ABS light will go back off.. I'm guessing I have a bad connection some where. I was doing some research on the Power steering issue and I read that the steering pump and the Brakes are linked together some how due to the Hydro Boost, and if thats the case maybe there is one issue that's causing all this to happen.. but I'm stumped because I didn't touch anything having to do with the power steering... any idea's would be greatly appreciated. thanks
-Josh
2008 f250 fx4 crew,spartan tuned running 250hp, dpf/cat removed with 4" turbo back, RCX 3" lift, 35's on stock 18's (for now), and lots more in the near future
Active Duty Navy, Machinest Mate
countryboy73703 is offline
post #2 of 9 Old 08-19-2013, 10:41 AM
Well comically, this 6.4 was my first Ford that the power steering pump didn't whine. Usually, they are super annoying!
Expirobo is offline
post #3 of 9 Old 08-19-2013, 11:04 AM Thread Starter
Quoted: 2 Post(s)
well don't jynx it.. ha well mine was quiet.. then I installed the lift, and then it whined.. I don't get it.. just coincedence? I don't mind replacing the pump since it's not that expensive but I want to make sure it's not something else cause this issue..
post #4 of 9 Old 08-19-2013, 12:54 PM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Maybe try flushing the power steering system. It cant hurt and maybe will fix it.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #5 of 9 Old 08-19-2013, 01:29 PM Thread Starter
Quoted: 2 Post(s)
Hmm... Well.. It just seems weird that it only started doing it after the lift.. Is there a better way to flush it with out having to siphon it out?
post #6 of 9 Old 08-19-2013, 01:36 PM
04hdfatboy's Avatar
Quoted: 4 Post(s)
This is how I did it and it worked well.
Ford Super Duty Power Steering Flush | Superdutypsd.com
08 F350 cc/sb 4X4
post #7 of 9 Old 08-21-2013, 06:39 AM Thread Starter
Quoted: 2 Post(s)
I did the flush as per the directions. the fluid was dirty, how ever I 'seemed' to have reduced the whining so a minimum, how ever this morning when I started her up, she was whining like before, so it didn't help the whining issue... I really feel like this is being caused because of something, and not because it's just a ford steering pump... I never had any noise coming from it period, until the change in suspension... if there was a strain on the pit man arm (factory arm) could that cause it? what about if the axle is shifted (waiting on adj. track bar) over an inch? this is all good info, I just feel like there is something more that I"m not seeing... and weird enough now that I think about it, if I remember correctly before I recentered my steering wheel it didn't whine.. and then after I centered it, it started to whine...
post #8 of 9 Old 08-21-2013, 06:52 AM
Well if you be careful while doing this, you can always jack of the front end and remove the load on the tires and suspension. Then fire it up and see if you reduce the noise. If it's caused by bad geometry in the new lift, relieving the stress should reduce the power needed from the power steering.
Might just get under there and see what's up. If things are off, there might be tension being applied somewhere in your steering linkage and that would cause the pump to while possible.
Expirobo is offline
post #9 of 9 Old 08-21-2013, 07:43 AM Thread Starter
Quoted: 2 Post(s)
Well that's what I'm thinking but I don't think anything is off... My ABS light comes on when I lock left but then goes away when I straighten out or turn right... And the pump whines the same regardless if I'm straight or turning, low speed or high speed... It only changes with the engine RPM's
