"Necessary mods"??? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 08-18-2013, 07:18 PM Thread Starter
blkrvrbart's Avatar
"Necessary mods"???
If you're going to make mods, in your opinions what are the necessary mods?
I hear all the talk and read about dpf deletes / tuners, egr deletes or coolers, cold air intakes, head studs. From a newcomers' standpoint it's all too much to throw into the truck at one time. Seems to me like you'd start with the head studs, then egr and dpf delete with the tuner, then if you ain't broke, a cold air intake and all the fun little stuff. Are the head studs a notable issue on the 6.4? Especially if it's already modded? I'm reading about uppipes and downpipes and coolers and AAAUUUGGHHH! I'm not going to hotrod this truck, I just want it to last as long as I possibly can make it last with the least amount of major repair expense. What do you say? What's the right mods if you're going to do a set-up with longevity and fuel efficiency in mind? (Not sayin' it ain't gonna get kicked in the slats once in a while to blow the soot out.)
blkrvrbart is offline
post #2 of 11 Old 08-18-2013, 07:33 PM
Studs are not needed in the 6.4s for 95% of us. If you just want reliability, delete the dpf and egr, flush the ford gold coolant out and run cat1 Rated elc, and get a coolant filter. Do all that and you'll be good to go.
For tuning I'd go h&s, but get it soon as they are getting hard to come by.
Moto2four is offline
post #3 of 11 Old 08-18-2013, 07:44 PM Thread Starter
blkrvrbart's Avatar
Thanks moto2four. Sweet ride.
post #4 of 11 Old 08-19-2013, 02:53 AM
Thanks bud. And welcome to the org
post #5 of 11 Old 08-19-2013, 09:20 PM
tony97gt's Avatar
Make sure you get the "race" tuner and not the street tuner, or you won't be able to delete. You won't find the race tuner on their site because they aren't allowed to sell it anymore, but some performance part dealers still have them or you can find them used here and there. Like stated above, I wouldn't be too concerned with head studs yet. Change all your fluids (oil, tranny- probably best to have the dealer do this one because of the method they use, rear diff) and your filters (oil,fuel) and make sure you use Motorcraft filters. Get a coolant filter soon and install it, they are pretty simple.
2008 F250 Harley Davidson 4x4, Upgraded LED lighting, JL Audio 13.5" Stealthbox, JL Audio C3 door speakers, JL Audio 500.1 for the stealthbox, JL Audio 400.4 for the doors, Viper 5704 alarm/SmartStart and GPS tracker, JimmiJammer door plates, JimmiJammer gateguard, Delete front lock/rear handle swap, DPF delete, MiniMaxx, 2.5" level, Sinister coolant filter, 55w 6000k HID's driving/fog lights, S+B CAI, MBRP 5" DP back exhaust, 35x12.5x20 TIS 20" rims, Nitto Trail Grapplers, adjustable track bar.
tony97gt is offline
post #6 of 11 Old 08-21-2013, 11:15 AM
wellsit's Avatar
Quoted: 9 Post(s)
Is replacing the Ford Gold Coolant necessary for these trucks too? I understand that the 6.0l was prone to the coolant "jelling" and clogging the cooler passages. Is that an issue with the 6.4 also?
08 F350 6.4
H&S Mini Maxx
wellsit is offline
post #7 of 11 Old 08-21-2013, 11:40 AM
06LariatF250's Avatar
Send a message via AIM to 06LariatF250
We have race tuners in stock. PM me for info
09 F250 CCSB Tuned by Eric, Trans built by Craig at MPD, DPC Converter, MPD S476 Single, Stage 2 Colt Cam, 100% MPD Inj., RCD Dual Fuelers, ARP's,20X12 Fuel Mavericks, 11.31@120 on fuel, 11.05@124 on a baby shot, 911hp fuel only
06LariatF250 is offline
post #8 of 11 Old 08-21-2013, 01:04 PM
superduty6.4's Avatar
If its maintained properly it seems to work well. Alot of people though are unaware of the maintenance of it and can have some issues. Alot of people switch to the ec-1 rated stuff for ease of maintenance of it.
08 F350 JOB 1
H&S MINI MAXX HD300 W/S1M
SINISTER EGR/COOLER DELETE
6000K BEAMERS HID HEAD & FOGLIGHTS
KMC XD WHEELS W/NITTO TRAIL GRAPPLERS
2.5" LEVELING KIT
DIESELSITE COOLANT FILTER
ROTELLA EC-1 RATED COOLANT
5" DP BACK FLO-PRO EXHAUST
FLO-PRO CAC PIPE & INTAKE ELBOW
CCV MOD
AIR LIFT 5000LB AIR BAGS W/ONBOARD COMPRESSOR
AFE CAI
PMF TRACTION BARS
superduty6.4 is offline
post #9 of 11 Old 08-21-2013, 02:44 PM Thread Starter
blkrvrbart's Avatar
Friend of mine says change the coolant and add a filter system. Don't think he'd steer me wrong.
post #10 of 11 Old 08-22-2013, 06:11 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
That is good advice
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
