Used H&S unlocked? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 08-18-2013, 10:12 AM Thread Starter
Used H&S unlocked?
Found a used H&S XRT Pro locally, guy said he did deletes on '11 Dodge. Took everything off when he sold the truck, back to stock.
How do I quickly verify that is Race unlocked and ready to use?
Guy thinks all is well, but not sure. Got a stock 6.4L and LML to try it.
Rather used the 6.4L to check it as warranty is out on it.
Just need a quick verify before exchanging $$.
seedguy is offline
post #2 of 9 Old 08-18-2013, 10:16 AM
SickStroke6.0's Avatar
Feedback Score: 9 reviews
Just power it up with the USB or OBD cable, go to settings, and there should be a "Status:" area that will either say "Unlocked" or it will have a VIN number.
Blake
2013 F-150 CCSB Oxford White FX4 EcoBoost
Loaded with every option...
2008 F-250 CCSB Dark Copper King Ranch 6.4L FX4
4" MBRP Exhaust w/ Muffler (DPF/DOC Delete), Modded Stock Intake, H&S XRT Pro
SickStroke6.0 is offline
post #3 of 9 Old 08-18-2013, 10:20 AM Thread Starter
Does "Unlocked" mean available to be used?
What about checking on the "Race" unlock for the DPF deletes?
seedguy is offline
post #4 of 9 Old 08-18-2013, 10:23 AM
Yes. On the main screen, it will also say in the bottom right corner "Power Level Not Available Until Download Installed."
You will have to begin a download and it will ask if the emissions are present or removed. After seeing that screen, just unplug it and it will cancel the download. If you continue clicking until the download actually starts, you will have to wait 15 minutes or so for the download to finish, and then another 15 minutes to return to stock.
Blake
post #5 of 9 Old 08-18-2013, 11:16 AM
Quoted: 48 Post(s)
these days it can get hairy looking at XRT PRO's because there are four different models. Most likely you're looking at an old race tuner. the firmwear number will tell you if it's a race tuner or street tuner.
on that show settings screen it will show tune installed or tune not installed. You want it to say tune not installed. You can also change vehicles to a different vehicle. If an H&S tuner is loaded to a vehicle, it won't let you change vehicles.
If you post up everything it says on the show settings screen, I can tell you exactly what you're dealing with
drunk on diesel is offline
post #6 of 9 Old 08-20-2013, 07:03 PM Thread Starter
Update- Checked out the guy's tuner, did not unload tune from truck that he sold.
It definitely was a race tuner, but still VIN locked for his previous truck.
I obviously did not buy it. Is there any value to it at all?
Still need something to do DPF/EGR on the 6.4L.
seedguy is offline
post #7 of 9 Old 08-20-2013, 07:15 PM
Nope. Tell him I'll give him $100 for it. But H&S won't even unlock it.
Blake
post #8 of 9 Old 08-20-2013, 07:16 PM Thread Starter
what will u do with it? Just curious.
seedguy is offline
post #9 of 9 Old 08-20-2013, 07:20 PM
Attempt to unlock it on my own. I'm in software engineering and I've been wanting to find a cheap locked tuner to work with.
Blake
