Elite Diesel CCV Kit - Ford Powerstroke Diesel Forum
post #1 of 17 Old 08-10-2013, 06:50 PM Thread Starter
I decided to go with Elite Diesel for my CCV mod. What a nice unit. Basically I'm done plumbing it in except for routing the hoses to the back. For those of you that have installed this where did you and how far back did you go with the hoses? I'm assuming that there are 2 hoses for the reroute, correct? I didn't know going farther back would present a problem since it's hard to get a good consistent flow downhill that way you wouldn't have a problem having oil pool up in the middle of the hoses? Any of you guys use a catch can or dump it in the exhaust besides the atmosphere with the Elite Diesel CCV Kit? Also what is the threaded hole on the side for? Please any advice would be great. Thanks in advance.
brkncly is offline
post #2 of 17 Old 08-12-2013, 10:03 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
I am debating between this kit and the dark horse diesel kit.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #3 of 17 Old 08-20-2013, 03:09 PM
2010KR350's Avatar
I made my own with a CCv filter and utilized the factory hose. Took 1 minute, looks good, no smoke no smell done. I can email or txt pics if needed
2010 F350 CCLB King Ranch. Mini Maxx Race - CAC Pipe - DPF MIA - Sinister Coolant Filter - Sinister EGR Delete - No Limit Intake - Custom CCV mod using stock parts - Devils Own W/M
13.01 @ 103
2010KR350 is offline
post #4 of 17 Old 08-20-2013, 07:18 PM
bongiardina's Avatar
I made my own also mine just has a standard valve cover breather on it under the hood without any issues.
bongiardina is offline
post #5 of 17 Old 08-21-2013, 07:39 AM
WoodBoy's Avatar
You can make your own for under 30$
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #6 of 17 Old 08-21-2013, 09:09 AM
2010KR350's Avatar
Thats exactly what I did.
13.01 @ 103
post #7 of 17 Old 08-22-2013, 03:49 AM
can you gusy that did it for $30 post some picts please. Im stoked to do this mod but don't want to spend 500 doing so.
08 JOB 1 F-250 Lariat Crew Cab, S&B INTAKE, H&S Blk MAXX, 5" Flo PRO, EGR Delete, Air Dog 165, Upgraded Bellows, MBRP Intercooler pipe, 4" Down pipe, Tial Wastegate, OUO T bars, ARP studs, Bestop pwrbrds
***Legal Disclaimer: Anything I say about my vehicle on this website(Powerstroke.org), pertaining to modifications, is only to gain acceptance from my peers, and does not actually represent anything actually existing on my truck, and thus, cannot be held against me in any issues.
08smoker08 is offline
post #8 of 17 Old 08-22-2013, 04:53 AM
StrokiNDieseL's Avatar
Pics? I bought the hornet kit(its not a kit)... Looks like a p.o.s. & only came w/canister. Been shopping for tubing, or different route.
08 F250 6.4L
CcSb Lariat 3.73
5200lbs springs, rear blocks removed, Nitto Grapplers
aFe Mag Force II Si pro 5R w/modded box
H&S MiniMax/Mcc & Gearhead tunes w/Blendmount
aFe Mach Force XP 4" Exhaust w/downpipe
Custom-Diesel Deleted, H&s wastegate w/Intake Elbow & CAC pipe, MPD Ccv/Oil fill mod, Alradco intercooler,
SD Coolant filtration/ CAT ELC...
StrokiNDieseL is offline
post #9 of 17 Old 08-22-2013, 05:15 AM
69Stang's Avatar
X2 I'd like to see pics and a material list if possible.
2010 F250 Cabela's Edition FX4, 6.4L, 3.55LS.
2011 Palomino Throroughbred 828RLS travel trailer.
"Democracy is two wolves and a lamb voting to have lunch. Liberty is a well-armed lamb contesting the vote!" Benjamin Franklin
69Stang is offline
post #10 of 17 Old 08-22-2013, 11:03 AM
WoodBoy's Avatar
CCV Reroute...Finally! - PowerStrokeNation : Ford Powerstroke Diesel Forum
WoodBoy is offline
