How tight to tighten CAC boots - Ford Powerstroke Diesel Forum
post #1 of 3 Old 08-10-2013, 06:49 PM Thread Starter
Getting ready to replace my old CAC boots since they are leaking. When installing the new ones how tight are you guys tightening them down to? Is there a specific torque rating? Don't want to over tighten the clamps nor do I want them to leak or loose pressure. Any input would be great, thanks!
brkncly is offline
post #2 of 3 Old 08-10-2013, 08:23 PM
I don't have my workshop manual with me right now, but I seem to remember them being spec'd at something like 11 ft/lbs. Whatever the number was, I remember it seeming low to me at the time.
B. Adams is offline
post #3 of 3 Old 08-10-2013, 08:35 PM
44magnum's Avatar
According to dieselsite the recommended torque spec is 60 in-lbs. I have had trouble with mine popping off so I have some of mine doubled clamped and they are all much tighter that 60 in-lbs or 11 ft-lbs.
If your replacing your boots I highly recommend the dieselsite ones, they come with new clamps and as far as I know they are the only ones that wont degrade because of oil.
also after I installed and double clamped my set I heard a good way to keep them from blowing off, hairspray, spray a bit on the pipe, slip the boot on, tighten and your good to go.
http://www.dieselsite.com/ford64ldie...tebootset.aspx
2008 (Job 1) F250 King ranch 4x4, snow plow prep package with 2.5 level. Black Maxx, B&W Diehard platinums. Dieselsite coolant and transmission filters, NCU Motorsports/amsoil oil bypass kit. Turbo blankets, 5.5 PMF traction
Please collect and message me Shell, Rotella oil cap codes aka "my miles matter" I'm trying to save up for a hat or something.
44magnum is offline
