Go Back   Ford Powerstroke Diesel Forum > Ford 08 and newer 6.4L Powerstroke Forums > 6.4L Performance Parts Discussion
Old 05-06-2008, 09:06 AM
Well put me down for a radiator
Truck was leaking coolant last night so I took it in this morning and they told me they are replacing the radiator. Guess this is that lovely common problem that has been in many posts...
Old 05-06-2008, 09:09 AM
"The Guy From Last Night"
Was it leaking from the behind the front bumper on the driver side frame rail??
Old 05-06-2008, 09:28 AM
Yes it was.. That seems to be the common place for that to occur correct?
Old 05-06-2008, 09:31 AM
Kummins Killer
Yeah, mine's doin that too! How bad did yours get before you brought er in?? I've already had to put a gallon of antifreeze in it, but its been leekin since last weekend-its not consistant yet though.
Old 05-06-2008, 09:37 AM
Mine was a small drip that I noticed by accident.. Usually when I am sitting in the parking lot and it will do its regen business, I will open the hood and I noticed a small drip, drip, drip and saw it running down the frame, so I caught it early...
Old 05-06-2008, 09:41 AM
Kummins Killer
So are they gunna cover it under warranty?? Did they say anything about a recall?? Because with all the aftermarket stuff I got, the warranty is out the window.
Old 05-06-2008, 09:43 AM
Yes everything is under warranty.. They are also going to fix the seat recall and there is a new one out from last week. Has to do with the fill neck on the fuel tank. Someone posted a picture with what looked like fuel residue from running down the side. They are going to fix that under warranty... At least that is what I was told...
Old 05-06-2008, 09:44 AM
No there is anything about a recall......try taking it to the dealer and just be cool with them about it.......the most they can say is no it won't be covered under warranty
Old 05-06-2008, 09:48 AM
Kummins Killer
True fact. I hope the radiator dont cost too much
Old 05-06-2008, 09:49 AM
Your lucky then.....mine came and went and then finally it was all the time
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.3.2
