Better Alternative to Factory HPFP? - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 20 Old 08-03-2013, 06:58 PM Thread Starter
Hey guys I have my truck scheduled to get head studs on September 3rd, I want to update he HPFP while the cab is off because ik they are a common failure point but I can't seem to find any type of updated or aftermarket pump on the market. Is there one out yet or do we just have to deal with the stocker and hope for the best?? Also is there anything else I should have done while its getting studs? Truck is an 08 build date 3/08, has dpf/egr delete, 5in exhaust s&b intake and spartan tuning. I want to be able to run the 310 tune with no issues (built tranny will come later) so what all will I need for fuel system upgrades? Any input is appreciated. Thanks.
torybarter likes this.
Trohrer01 is offline
post #2 of 20 Old 08-03-2013, 07:11 PM
Duel fuelers will take the load off the stock pump.
Moto2four is offline
post #3 of 20 Old 08-04-2013, 08:51 AM
08stroker250's Avatar
You technically don't need any fuel system upgrades to run the 310 tune. I would start with an Air Dog though. That alone will help your HPFP due to better filtration.
Jeff Dodd
2012 Ford F-250 Lariat CC/SB
Mods - Spartan tuned via laptop, 4" AFE stainless exhaust system, 2.5" PMF BMC leveling spacers, 3" PMF lift blocks, Fox Racing 2.0 shocks, Recon smoked mirror & cab lights
08stroker250 is offline
post #4 of 20 Old 08-05-2013, 06:04 PM Thread Starter
Ok, the main reason I'm asking is because the shop I'm getting to do my studs recommended that I put a new HPFP in while he has the truck apart that far. I asked him if there was an update on the pump and all he could tell me is that the part number changed, this is a shop that specializes in powerstrokes but they have done hundreds of 6.0s and only a dozen or so 6.4s. i knew an air dog would be a good idea but I thought I might want larger injector nozzles? would the stock setup handle the 350 tune?
post #5 of 20 Old 08-05-2013, 07:30 PM
Part number changed from rev A to rev B. I think this was in 2011. Don't remember specific changes.
2008 F350 6.4 4x4 DRW CC 4:10 King Ranch Job3
Max2006 is offline
post #6 of 20 Old 08-05-2013, 08:34 PM
WoodBoy's Avatar
Stock HPFP isn't going to maintain any bigger nozzles. You will need a dual fueler setup. And there is no since really in running bigger nozzles since air is the limit at the time
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #7 of 20 Old 08-06-2013, 05:09 AM Thread Starter
Ok, would it still be beneficial to run a dual fueler setup to keep load off if the stock pump like moto2four said? Does anyone know what the changes were to the newer hpfp?... I was also wandering if there were aftermarket rocker arms that would be worth upgrading to while the heads are off?... Sorry for all the questions guys! Haha
post #8 of 20 Old 08-06-2013, 07:13 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Who makes aftermarket rocker arms?
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #9 of 20 Old 08-06-2013, 09:28 AM Thread Starter
Idk if anyone does, I was just wandering if there are any out there that are stronger than the factory rockers.
post #10 of 20 Old 08-06-2013, 09:52 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
I would just stick with the OEM rockers. You can get all of them for like $300. I think I remember reading that they updated the design.
08 F350 cc/sb 4X4
