Which tinner to go with? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 08-02-2013, 05:00 PM Thread Starter
Jerzyperson's Avatar
So I'm sure I'm going to be good to research through here. But I can't pattern the good and bad. So I want to localize it all in one thread. I'm getting my deletes next week for my new 08. Egr, and dpf/cat. And want to know what tuner to go with. I'm leaving towards Spartan. But I will be getting bigger rims and Tits so I will need tpms deleted. And h&s does that. I like the dashdaq and really like the tunes. But again. H&s had all their deletes. So what's all of your opinion? If I get the Spartan. Can I barrow an h&s to do the deletes. This is where I'm stuck is tuner. Thanks for any input.
Jerzyperson is offline
post #2 of 10 Old 08-02-2013, 05:05 PM Thread Starter
I'm new to 6.4 so I'm not sure what all I Need to do to do the egr. I just read that I need a tuner to properly delete? Why is that? Do I need it to do my dpf/cat delete as well?
post #3 of 10 Old 08-02-2013, 05:31 PM
superduty6.4's Avatar
you will need to delete the dpf as well if you want to do the egr delete. I don't think it's possible to only do an egr delete. You need to tuner for the deletes so the truck won't throw any codes or go into limp mode.
08 F350 JOB 1
H&S MINI MAXX HD300 W/S1M
SINISTER EGR/COOLER DELETE
6000K BEAMERS HID HEAD & FOGLIGHTS
KMC XD WHEELS W/NITTO TRAIL GRAPPLERS
2.5" LEVELING KIT
DIESELSITE COOLANT FILTER
ROTELLA EC-1 RATED COOLANT
5" DP BACK FLO-PRO EXHAUST
FLO-PRO CAC PIPE & INTAKE ELBOW
CCV MOD
AIR LIFT 5000LB AIR BAGS W/ONBOARD COMPRESSOR
AFE CAI
PMF TRACTION BARS
superduty6.4 is offline
post #4 of 10 Old 08-02-2013, 06:00 PM Thread Starter
I'm going to be ordering my whole new exhaust dpf/cat delete and egr delete next week. But won't be getting a tuner for a little bit. Would I have to barrow a tinner to do the deletes? Or wait till I buy mine to put them on?
post #5 of 10 Old 08-02-2013, 07:07 PM
Echo's Avatar
You will need to have a dpf delete capable tuner installed before you can put the dpf delete pipe and egr block off plates on.
Echo is offline
post #6 of 10 Old 08-02-2013, 07:27 PM Thread Starter
Im thinking about going with Spartan. Are they delete capable?
post #7 of 10 Old 08-03-2013, 03:29 AM
Echo's Avatar
Yes a spartan tuner will work
Echo is offline
post #8 of 10 Old 08-03-2013, 05:37 PM
What size tits are you going up to?
2008sixfour is offline
post #9 of 10 Old 08-03-2013, 06:40 PM Thread Starter
I like a DD numbers don't matter. Oh you mean tires. I only plan to go 33s
post #10 of 10 Old 08-03-2013, 06:57 PM Thread Starter
I just bought my new rims. 18x9.5 just need to wrap em in rubber
