Diesel site tranny filter, easy to install? - Ford Powerstroke Diesel Forum
post #1 of 34 Old 08-01-2013, 07:54 PM Thread Starter
I just got the diesel site external tranny filter. Is it pretty easy to install? Any tips on doing it? I have a job 1 if that matters or not.
08 F350 crew 4x4
H&S mini, Sinister egr delete, cold side pipe, 5" straight pipe, S&B intake, 3.5" level, Newton bars, coolant filter, 325's duratracs, ARP studs, 6.0 manifolds, flow pro DP, Detroit truetrac, triple disk converter, led bed lights
79 F350 4x4 460ci
blk450er is offline
post #2 of 34 Old 08-01-2013, 08:44 PM
44magnum's Avatar
Ya its pretty easy to install. The worst parts are mounting the filterhead and figuring out where you want to run the lines. No tips I can think of, just make sure you use flare nut wrenches.
2008 (Job 1) F250 King ranch 4x4, snow plow prep package with 2.5 level. Black Maxx, B&W Diehard platinums. Dieselsite coolant and transmission filters, NCU Motorsports/amsoil oil bypass kit. Turbo blankets, 5.5 PMF traction
Please collect and message me Shell, Rotella oil cap codes aka "my miles matter" I'm trying to save up for a hat or something.
44magnum is offline
post #3 of 34 Old 08-01-2013, 08:55 PM Thread Starter
I see you have both the diesel site coolant and trans filters. Got a pic of how you mounted yours?
08 F350 crew 4x4
79 F350 4x4 460ci
blk450er is offline
post #4 of 34 Old 08-02-2013, 07:32 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
I also have both. I will see if I can go out in a few and snap a picture.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #5 of 34 Old 08-02-2013, 07:48 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Here is how I have mine mounted.
08 F350 cc/sb 4X4
post #6 of 34 Old 08-02-2013, 08:11 AM
ZMANN's Avatar
Quoted: 1338 Post(s)
assuming you have the early job 1 divorced filter ( either near the bell housing or the toilet paper roll up front depending on build date) and in pan screen
return or sell that kit and get the job 2 in pan real filter and a OEM ,Derale,Mag pan and filter fluid 100% of the time vs
a small percentage run through the cooler lines that are bypassed most times
We Miss you Ronnie
ZMANN is offline
post #7 of 34 Old 08-02-2013, 08:23 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Doesn't the dieselsite kit filter the fluid 100%? I think it does but I am not sure.
08 F350 cc/sb 4X4
post #8 of 34 Old 08-02-2013, 08:26 AM
ZMANN's Avatar
doesn't it tie into the cooler line ?
if so then it can't and I also can't think of how they would rig it any other way ?
We Miss you Ronnie
ZMANN is offline
post #9 of 34 Old 08-02-2013, 08:29 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
This is from their website...
We have the only full flow system on the market with a built in bypass valve. This insures that should the filter plug with debris, fluid will still return to the transmission. A filter housing with a bypass valve is NOT the same as a bypass filter. A bypass filter typically "samples" the fluid and filters only a small amount on each pass. As the filter gets dirtier, less will get sampled and more unfiltered oil returns to the pan. Our unit -- a housing with a bypass valve-- filters ALL the fluid on every pass when the filter is clean. Only when the filter becomes very dirty does it enter "bypass mode". At that point it will act as a "sampling" type filter similar to the bypass filter.
08 F350 cc/sb 4X4
post #10 of 34 Old 08-02-2013, 08:35 AM
ZMANN's Avatar
I will go on record to say there info is flawed in a few areas
like making it easy to drain the converter
Allows the addition of the transmission flush valve to make torque converter purging easier.
thats BS unless you can keep the trany up to 180* and the fill fluid at the same temp otherwise the cooler circuit will not have full flow
and the comment on the in pan screen since We all know ford has put a real filter on the suction side despite the comments diesel site states that is not possible LOL
oh and they state no more pan drop but fail to mention the newer 5r110w in pan filter will catch debris long before the filter in a bypass cooler will so it will need regular service
http://www.dieselsite.com/2008-20106...tersystem.aspx
We Miss you Ronnie
ZMANN is offline
