not enough boost with new tuner - Ford Powerstroke Diesel Forum
post #1 of 4 Old 07-31-2013, 09:02 AM Thread Starter
stroker80's Avatar
I have a 2008 f250 and it has a dpf and an egr delete on it as well as an afe intake and an sct livewire with innovative tunes. The question I have is where is the egr pressure sensor located on this truck? I cannot build over 30lbs of boost and my truck lags pretty bad when you stand on it as well as the unforgivable dyno numbers I just recorded. I put an egr delete on my buddies 6.0 and it still lagged in the same sort of scenario so I looked into it and we found the problem to be the exhaust pressure sensor, so I was wondering if it would possibly be the same sort of scenario on my 6.4 where I could clean it or replace and solve the problem. Thank you for taking the time to reply before hand.
stroker80 is offline
post #2 of 4 Old 07-31-2013, 09:48 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Take off your map sensor and ebp sensor and tube and clean them. I replaced mine just to be safe. That would cause boost problems. Here are pictures of where the sensors are located.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #3 of 4 Old 07-31-2013, 10:12 AM
Ditto ^^^^^
2010 Ford F-250 Super Duty, Lariet 4x4, Crew Cab Short Bed, loaded with every option...and more
turbo kidd is offline
post #4 of 4 Old 07-31-2013, 06:31 PM
srjd's Avatar
Quoted: 2 Post(s)
I replace those sensors once a year now and it does make a difference
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
