6.4 exhuast sound change ? - Ford Powerstroke Diesel Forum
post #1 of 44 Old 07-30-2013, 05:37 PM Thread Starter
RachHandinit's Avatar
Does anyone have any custom tunes that change the sound of the exhaust. Not looking for a loop tune but looking for something other than the hairdryer sound. I am running a H&S mini maxx if that helps.
Thanks.
09 F-250 King Ranch
H&S Mini Maxx/ HD Tune/ 5" Flo~Pro/ AFE PDS Intake
Leveling Kit with 37x12.50 R20 Nitto Trail Grapplers
CCV Mod
RachHandinit is offline
post #2 of 44 Old 07-30-2013, 06:49 PM
Change out your downpipe.... completely changes the drier vent sound.
08 F350 XLT LONG BED toyo at2 35x12.5x18, rancho 4" lift pro comp dual stering stabilizer, spectra radiator, banks ram air, flo pro egr delete,cac pipe, 4" down pipe to 5" exhaust 6" tip arp head stud stage 1 valve springs, stage 1 push rods, coated international pistons,
next: AIR DOG 165, 71mm atmo turbo
acbydennis is offline
post #3 of 44 Old 07-30-2013, 07:03 PM Thread Starter
What would be some suggestions?
09 F-250 King Ranch
CCV Mod
post #4 of 44 Old 07-30-2013, 07:06 PM Thread Starter
Seen some videos of people messing with single turbos and different mm numbers. Can anyone elaborate on that any?
09 F-250 King Ranch
CCV Mod
post #5 of 44 Old 07-31-2013, 07:01 PM
travisH3's Avatar
Quoted: 2 Post(s)
Feedback Score: 13 reviews
The twin turbos are what quiet it down. The people with singles that you see videos of sound alot more like a 6.0. I wish I could get my 6.4 to sound better without swapping turbo set ups
T-rav
2010 F350 6.4-
s467 MPD single kit, H&S Jesse Byall tuning, No limit IC piping and intake,mishimoto intercooler, MPD billet CCV/oil filler, FASS with sump, SOTA A.W.O.L. polished wheels, toyo rt tires, RED Newton traction bars, oem projector retrofit and a bunch of LED lights LOL
Holderdown Performance #teamHDP
OUR FLEET: 2015 f450, 2014 Platinum F350, 2012 F450 6.7, 2010 F350 6.4, 2005 F350 6.0, 04 F450 6.0
travisH3 is offline
post #6 of 44 Old 08-01-2013, 06:04 AM
countryboy73703's Avatar
Quoted: 2 Post(s)
I've got a 4" downpipe back... I get the "jet" noise, or the Hair Dyer noise... In my opinion there's not gonna be a tune that changes your exhaust sound.. the only thing you can do is actuall tinker with exhaust components.. with that being said I'm assuming that your deleted, so your best bet is to by a muffler.. it will still sound good, won't be obnoxiously loud, and from what I've heard it will help to eliminate that hair dryer noise.. I personally don't mind it.. I like that looks from people
countryboy73703 is offline
post #7 of 44 Old 08-01-2013, 02:30 PM
WoodBoy's Avatar
You can actually play with your turbo veins and change the sound a lot. If you have MCC you can put the VGT to wide open at idle and have it go back to normal at 800RPM. This will give you a throaty sound
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #8 of 44 Old 08-01-2013, 02:33 PM
Quoted: 2 Post(s)
MCC? And right but its not going to change it ... Like while driving
post #9 of 44 Old 08-01-2013, 02:50 PM
WoodBoy's Avatar
You can change it if you want at all areas if you prefer, but you may have to change your driving habits. Just unplug your VVT plug and you will see what I am saying. I actually have a tune that I use that has the veins open a lot, while it still has some what of a hair dryer noise, most of it is gone.
Here is a post from Mike Haller:
set the desired back pressure table to 0 psi up to 1k rpm. then set vane position tables up to 1k rpm to 0%. the vanes will kick open at idle then close and resume normal operation after 1k rpm. I did this on my drag truck and it sounds pretty cool.
WoodBoy is offline
post #10 of 44 Old 08-01-2013, 05:04 PM Thread Starter
Would you mind posting a video?
09 F-250 King Ranch
CCV Mod
