CCV mod, tie into exhaust, catch can or atmoshere? - Ford Powerstroke Diesel Forum
post #1 of 46 Old 07-25-2013, 05:21 PM Thread Starter
I'm going to be doing a CCV mod on my '08 F-350 after I figure out which kit I want. The next question is should I tie it into the exhaust, use a catch can or let it vent into the atmosphere? What are most of you guys doing for those of you guys that have done this mod? What are the advantages and disadvantages between each other? I like the idea of tying into the exhaust with a 45 degree bung but afraid that it will add back pressure and where at on your exhaust pipe do you weld the bung to? What are your guys thought on this and Thank You!
brkncly is offline
post #2 of 46 Old 07-25-2013, 05:55 PM
Term3's Avatar
I've seen, built and helped install every form of CCV mod. A fair amount of guys just run a hose to somewhere back of the cab which can, on some trucks, produce some smoke, oil drips and stink. Care must be taken to not have any low spots that can collect moisture and freeze. Building your own is fairly easy as long as you don't create any backpressure (I can email you some picks of the one I made if you want. I can't post pics for some reason anymore). I've built my own but replaced it with a larger Raycor CCV filter which has an indicator for when the filter is getting plugged and also has an electric warmer for real cold weather operation. Some guys that just use a hose vented to the atmosphere have noticed that their engine leaks oil a little more. I've also seen one put into the exhaust downstream from the muffler with a 1" tube with the end cut at a 45 degree angle and the tube installed at a 45 degree angle which seemed to work well. IMO best way to go is a better CCV canister routed back to the intake so that there is always a slight vacuum on the system.
Sent from AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #3 of 46 Old 07-25-2013, 08:59 PM
superduty6.4's Avatar
I vented mine to atmosphere. I ran it across the top of the motor, down the area where the EGR coolers used to be and then in behind my front number. The fan seems to keep all the smoke and smell away. I did a fairly long tow a couple weeks ago an the truck was working pretty hard. I crawled underneath and could see the smoke coming out of the hose but when I popped my head back up there was no smoke or smell at the front of the truck. Works well for me. Even in the winter I don't see any smoke unless I crawl underneath.
08 F350 JOB 1
H&S MINI MAXX HD300 W/S1M
SINISTER EGR/COOLER DELETE
6000K BEAMERS HID HEAD & FOGLIGHTS
KMC XD WHEELS W/NITTO TRAIL GRAPPLERS
2.5" LEVELING KIT
DIESELSITE COOLANT FILTER
ROTELLA EC-1 RATED COOLANT
5" DP BACK FLO-PRO EXHAUST
FLO-PRO CAC PIPE & INTAKE ELBOW
CCV MOD
AIR LIFT 5000LB AIR BAGS W/ONBOARD COMPRESSOR
AFE CAI
PMF TRACTION BARS
superduty6.4 is offline
post #4 of 46 Old 07-25-2013, 09:13 PM
Clayton1985's Avatar
I ran my hose along firewall back towards air filter and stuck end of hose in a coffee mug wedged between firewall/air filter housing area. The fumes go right back into intake and no dripage on driveway or truck.... Kind of crude but does the trick.
2008 Job 3, F350, 6.4/drw/lariat/CC/LB, Spartan, Viper 5902, Line-X, Flo-pro egr delete, aFe stage 2 proguard 7, MBRP Cool Duals/downpipe/CAC, CCV mod, coolant filter PMF 7" 4link, Rigid Dually fogs, Royalty Core 3pc, Crown brake lines, Mishimoto Rad
6.4 Rebuild May/2015, BD manifolds+Uppipes, chromoly rods, rockers,lifters, hd springs
Monstir 20", 37x12.50 ATZ P3
1999 Corvette Cpe
Clayton1985 is offline
post #5 of 46 Old 07-25-2013, 09:38 PM
superstack's Avatar
I ran mine down to the frame rail and back to 90 from my exhaust elbow for my stack, then put in a hard elbow in the ccv hose and over to the exhaust where I tacked a 90 elbow to the exhaust stack. Kept it as level as possible and used hard elbows to stop the hose from kinkin or breakin over time. Cant smell it, see smoke and never drips. Over kill I tell ya...
superstack is offline
post #6 of 46 Old 07-26-2013, 11:20 AM
Trackstand's Avatar
What is a CCV mod and whats the gains of doing this? thanks
2013 Dodge Ran 2500 4X4 crew cab long bed
Trackstand is offline
post #7 of 46 Old 07-26-2013, 12:10 PM
Term3's Avatar
The OEM crank case ventilation set up is not capable of knocking out very much of the oil vapor that comes with the blow-by gasses coming out of your engine. So what happens is the oil vapor condenses out all thru your intercooler and intake manifold. An oil coated intercooler is not as efficient. So the mod is making a better oil vapor remover or just venting the vapor straight to the atmosphere.
Term3 is offline
post #8 of 46 Old 07-26-2013, 12:32 PM
Trackstand's Avatar
So where is the hose to tap into and do I plug the intercooler hole?
post #9 of 46 Old 07-26-2013, 12:41 PM
04hdfatboy's Avatar
Quoted: 4 Post(s)
The hose runs between where you put oil and your air intake. There is no hole on the intercooler that you need to plug.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #10 of 46 Old 07-26-2013, 07:50 PM
Powerstrokin_08's Avatar
Quoted: 5 Post(s)
I used NC Hornets CCV mod and the best explanation I've gotton on the CCV is that you need to route to a catch can then back to the intake to create a vacuum. All of the residue and oil is caught in the can and drained at oil change. Gases go through the intake cleaned of oil and burned. This is the best explanation I've heard on how to route the CCV
2013 King Ranch F-250 CCSB 6.7L 4x4
Carli 2.5" Leveling Kit
4" Rear blocks
Bilstein 5100's
AMP Research steps
Plain and Simple Custom Headlights
35" Toyo MT's on King Ranch rims
Fab Four Black Steel bumpers front and back
5" Flo Pro
No Limit EGR/Cooler Delete
Edge CTS2
PPEI EzLynk
*SOLD*2008 F-350 CCSB 6.4L 4x4
4" DP back
H&S Mini Max
Sinister EGR/Cooler Delete w/Intake Elbow
Carli 2.5 Pin Top Suspension
S&B CAI
NC Hornet CCV mod
20's&35's
Powerstrokin_08 is offline
