2010 F350 running inconsistantly - Tuned - Ford Powerstroke Diesel Forum
post #1 of 21 Old 07-22-2013, 09:08 AM Thread Starter
Hi all
Need some help on this one. Its kinda got me stumped.
2010 F350. 62,000 Km. Spartan tuned. Stock tires. The truck is in immaculate condition.
I pull a 38' toyhauler. Weighs about 17,000# loaded.
Usually, the truck pulls great. Although, I am not totally happy with the 3.55 gears(wouldnt reccomend them to anyone pulling heavy).
What I am noticing is the truck will pull great for 30- 90 min and then it turns into a total dog!
When it is running good, it will pull my trlr up certain grades in high gear and makes 41-43lbs boost in the 210 tow performance. The EGT's dont exceed 1200-1250.
When it starts $hiting the bed it will only make 35- 38lbs of boost and will sometimes have to unlock the converter to make the same hill. The EGT's also go up to 1400. It has a tough time pulling the trailer across the flats in high gear!! It sounds like it is running good but just wont pull. This thing is also a pig on fuel when i am pulling compared to my 08.
I have tried the 210 early lock up, 210 late lock, and both 210 tow performance. I dont think it has anything to do with the tuning.
I have scanned for codes and nothing came up.
Any ideas?
thanks
2010 F350 Crew Cab Long Box
Spartan , S&B Intake 3.55
Redram99 is offline
post #2 of 21 Old 07-22-2013, 10:00 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
First thing I would do is take off and clean the map sensor and ebp sensor and tube. Could be that your ebp sensor tube is clogged.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #3 of 21 Old 07-22-2013, 03:13 PM Thread Starter
Sorry man... what is the map sensor and ebp sensor.
I belive the map sensor is the one in the intake, right?
Redram99 is offline
post #4 of 21 Old 07-22-2013, 03:35 PM
EBP is your exhaust back pressure sensor. When the sensor or tube gets clogged with suit it causes erratic behavior
makaveli200369 is offline
post #5 of 21 Old 07-22-2013, 03:42 PM Thread Starter
Where is it?
thanks
Redram99 is offline
post #6 of 21 Old 07-22-2013, 04:34 PM
Originally Posted by Redram99 View Post
Where is it?
thanks
post #7 of 21 Old 07-24-2013, 08:12 AM Thread Starter
I forgot to mention... the little air compressor that the EBP sensor is near seems to be cycling a whole lot lately. I will report my findings.
Thanks for the help!
Redram99 is offline
post #8 of 21 Old 07-24-2013, 08:36 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Are you talking about the vacuum pump that is mounted on top of the fuse box?
08 F350 cc/sb 4X4
post #9 of 21 Old 07-24-2013, 09:04 AM Thread Starter
Yes, i think so. It is beside and below the master cylendar.
It is running about 70% of the time for some reason....
Redram99 is offline
post #10 of 21 Old 07-24-2013, 09:18 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Yea that's the vacuum pump. You must have a vacuum leak somewhere.
08 F350 cc/sb 4X4
