Traction Bars Help. And Upgrade Help! - Ford Powerstroke Diesel Forum
post #1 of 23 Old 07-20-2013, 12:58 PM Thread Starter
baddzul's Avatar
Question Traction Bars Help. And Upgrade Help!
First time to the site looks like im going to find a lot of useful information here but here is my setup and my problem i have h&s mini maxx race tuner on hot damn hot tune with afe stage 2 intake, water methanol injection system (yes i know it doesn't help much but it does enough for egts of what i needed but disappointed in hp gains if any?) and cal trac traction bars. still getting pretty nasty wheel hop or axle wrap on launches i have "tuned" the bars down to the rollers barely pressing on leaf spring with me in the cab any help or advice if i could launch at 20 psi that would be amazing at the track but any launch over id say 10-14 psi i get bad wheel hop. Also i have tried my tire psi at anywhere from 35-40psi any help is greatly appreciated. As far as REAL NEAR FUTURE upgrades go what does everyone think of me doing a cac pipe upgrade,CCV Mod To Catch Can and turbo socks or what is an affordable noticeable gain i haven't done, Also Which CCV Mod Is Recommended. I have the egr delete kit but i have not executed it yet on the truck if i did that would i notice a difference since i already have it turned off through the tuner? THANKS IN ADVANCE for all your greatly appreciated advice!
baddzul is offline
post #2 of 23 Old 07-20-2013, 01:44 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Welcome to the site. Looks like your bringing a boat load of info.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #3 of 23 Old 07-20-2013, 01:45 PM
BIG Laing's Avatar
I have never heard of cal trac before. Are they weld on, or bolt on?
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #4 of 23 Old 07-20-2013, 01:49 PM
BBBRRRRRTTTTT
powerstrokeshellback's Avatar
Quoted: 110 Post(s)
Feedback Score: 7 reviews
Warm up the tires and lower air pressure to help them hook. How about air bags?
God bless America, the Constitution and the Second Amendment.
2016 F-250 Super Crew XLT 6.7L
2007 F-250 Super Cab XL 6.0L (sold)
powerstrokeshellback is offline
post #5 of 23 Old 07-20-2013, 02:12 PM
xpbprox's Avatar
And 4x4 launch
04 F-350 XLT FX4 CC LB SRW leveled, SCT w/ innovative tunes, Edge Insight gauges, Str8 pipe, Studs, Bulletproof EGR, valve seats, 6.4 banjo bolts, updated fuel pressure spring
89 F-350 Centurion Lariat 4X4 CC BB STW lifted on 35"s
460 E4OD
6.0 BIBLE
xpbprox is offline
post #6 of 23 Old 07-20-2013, 02:48 PM Thread Starter
baddzul's Avatar
i do launch in 4x4 hi and have already tried heating up the rear tires and low tire pressure like 35psi and cal tracs are surprisingly pretty well known i thought Calvert Racing - The Leader in Leaf Spring Innovation
baddzul is offline
post #7 of 23 Old 07-20-2013, 02:49 PM Thread Starter
baddzul's Avatar
dont mean to overload anyone just lots of questions haha
baddzul is offline
post #8 of 23 Old 07-20-2013, 02:55 PM
xpbprox's Avatar
Do you have an kind of lift?
You can remove the stock
Blocks and put some lift springs to make up for the removal of the blocks. The blocks encourage axle wrap
460 E4OD
6.0 BIBLE
xpbprox is offline
post #9 of 23 Old 07-20-2013, 03:03 PM Thread Starter
baddzul's Avatar
no stock lift but ill see about removing the blocks any advice on adjusting the cal tracs
baddzul is offline
post #10 of 23 Old 07-20-2013, 03:29 PM
xpbprox's Avatar
Well if you want less axle wrap then you're gonna want to have the bars adjusted so that they have pressure against the axle. It sounds like you have them too loose from reading your first post.
460 E4OD
6.0 BIBLE
xpbprox is offline
