time for the inevitable...cab off, what else? - Ford Powerstroke Diesel Forum
post #1 of 14 Old 07-16-2013, 08:31 PM Thread Starter
RJD
RJD's Avatar
I'm finally coming out of denial, time to address my blown head gaskets. I'm probably going to do it myself and figured while I have the cab off anyway I might as well make the most of it. What I'm thinking now is ARP studs, ford gaskets, get heads magnafluxed, 6.0 exhaust manifold with custom upipes, and possibly a ported intake manifold. These worth it? Anything else I should do while I'm in there? For reference, I already have s&b intake, egr delete, intake elbow, cac pipe, air dog 2, ccv mod, coolant filter, 4" exhaust, and a minimax.
Also, can anyone interpret this picture? It looks like coolant, but I'm afraid to ask why it looks like it's coming out of the exhaust manifold. This is the only place I could find this, the rear of passenger side.
RJD is offline
post #2 of 14 Old 07-17-2013, 04:45 AM
matted2thefloor's Avatar
Thats definitely coolant...it's NOT coming from the exhaust manifold.
As far as other things to do...I'd do thermostats and an oil cooler. If the truck sees a lot of heavy work, might also pull the water pump and check the front cover for cavitation...probably replace the water pump too. Head gaskets probably went south because either the bolts stretched (too much boost psi), overheated or both.
08 F350 CCLB 4x4 Lariat Job 3
Over 200k on the ticker... Living healthy with the help of some goodies!
matted2thefloor is offline
post #3 of 14 Old 07-17-2013, 06:39 AM Thread Starter
RJD
RJD's Avatar
I guess it makes more sense that the coolant is running down the side of the block and seeping between the block and the exhaust manifold gasket. I can't really see above the manifold to see where its coming from though. Time to bust out the mirror
RJD is offline
post #4 of 14 Old 07-17-2013, 10:08 AM
It's coming out in between where the cylinder head sits atop the block.
post #5 of 14 Old 07-17-2013, 10:42 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Nate (windrunner408) is porting an intake manifold for me. I would recommend him if you decide to do a ported intake manifold.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #6 of 14 Old 07-19-2013, 04:45 AM
AZ_stroker's Avatar
I was quoted around $6-$7k for this job by a local reputable shop. Is that normal?
2008 F250 CCSB 4X4
Pueblo Gold
High Idle Mod, H&S Mini Maxx, 4" SS FloPro exhaust, S&B oiled Intake Filter, Mishimoto Radiator. BG Products fluids in power steering, brakes, coolant, oil, and tranny.
AZ_stroker is offline
post #7 of 14 Old 07-19-2013, 10:53 AM
Dont Mess With Texas!
ThirdCoastStroker's Avatar
Quoted: 14 Post(s)
AZ maybe a hair on the high side, I had all the same work done for right at $5k
studs, gaskets, egr delete, new oil cooler, intake elbow, cac pipe, coolant filter system, CAT ELC coolant, and new oil and a few other things.
Casey
New Truck
15' F-350 King Ranch 4x4 CCLB
Platinum White / Caribou Metallic
Stock for now!
Old Truck
08' F-350 King Ranch 4x4 CCSB
H&S Mini Maxx 300 HD
5" Straight Pipe to 7" rolled tip
AFE S2 PDS
ARP Head Studs
FloPro EGR Delete with Intake Elbow
FloPro CAC pipe
Rebuilt beefed up OEM Up pipes
Deisel Site Coolant Filter
Firestone RideRite Airbags
Leveled
35X12.50R20 ProComp Xtreme A/T
Ranch Hand Front and Rear Replacement Bumpers
ThirdCoastStroker is offline
post #8 of 14 Old 07-19-2013, 01:09 PM Thread Starter
RJD
RJD's Avatar
ThirdCoast, what prompted you to replace the oil cooler? Preventative or did you know it was bad? I run 4-6 degrees difference between oil and coolant temps when i'm empty on the highway. This should be normal right?
RJD is offline
post #9 of 14 Old 07-19-2013, 01:37 PM
04hdfatboy's Avatar
Quoted: 4 Post(s)
That is normal and the oil cooler is working as it should. When it starts getting closer to 15+ is when you need to worry about replacing it.
08 F350 cc/sb 4X4
post #10 of 14 Old 07-19-2013, 01:43 PM Thread Starter
RJD
RJD's Avatar
okay thanks, thats what i was thinking. i figure if my oil cooler ever does go out down the road I'll just replace it with a bulletproof cooler, as those can be installed cab off
RJD is offline
