blown injector with spartan tuner ?? - Ford Powerstroke Diesel Forum
post #1 of 42 Old 07-09-2013, 05:32 PM Thread Starter
my nightmares have returned from my 6.0 now to my 6.4, Im pretty sure almost 100% i blew an injector today with a spartan tuner .. truck had a little shake to it for a day or 2 nothing that bad but as i was driving today the shake got worse than i herd a clank clank clank sound and i covered a 4 lane road with white/blue smoke so bad that cars where coming to a complete stop ... like i said im pretty sure it is an injector, I installed the tuner at about 18,000 miles and its been on for about 29,000 miles with no problems except for radiator started leaking and had it replaced ive been pretty much running the 250 tune the entire time, I am just wondering if anyone else has had this problem and how often and do you guys think it is bc of the tuner and if anyone knows of a mod friendly dealer located in NJ bc i am still under warranty and would love not to come out of pocket for this ... thanks all and there probably is a thread about this i just couldnt come across it
f250turboback is offline
post #2 of 42 Old 07-09-2013, 07:10 PM
WoodBoy's Avatar
Have you checked your blow by? Cracked piston maybe. I haven't heard of someone "Blowing" an injector on a 6.4
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #3 of 42 Old 07-09-2013, 08:41 PM Thread Starter
i might have worded it wrong but i really hope its not somthing like a cracked piston ...it was making a really load ticking sound ...but wouldnt it have thrown a check engine light i might be wrong but thats why i ask for help but thanks for the reply woodboy .. i will check tomorrow on the dashdaq and see is any codes pop up and i was taking a log on the dashdaq when this all happend ... and another thing i do not beat on this truck i rarely even give it half throttle but i do tow a 20ft enclosed full of mowers and dump trailers with heavy loads
post #4 of 42 Old 07-09-2013, 09:14 PM
Quoted: 48 Post(s)
sounds like you torched a piston
drunk on diesel is offline
post #5 of 42 Old 07-10-2013, 07:47 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Is there oil coming out of the ccv or anywhere else? I think usually that will happen with a cracked piston. The ticking sound could also be a broken rocker arm. Mine made a ticking sound when that happened.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #6 of 42 Old 07-10-2013, 12:30 PM
WoodBoy's Avatar
Broken rocker arm, bent pushrod, there are a number of things
WoodBoy is offline
post #7 of 42 Old 07-10-2013, 05:33 PM
My truck flashed a code when it cracked #2 piston... when you lose it it pops and the white goes real bad. Also had rocker arm fall off. When that happened it felt like a miss. Alittle white smoke but flashed a code on the tuner not till I stopped at idle did it flash the check engine light.
acbydennis is offline
post #8 of 42 Old 07-10-2013, 07:11 PM
WoodBoy's Avatar
Check your glow plug harness to see if it is pushed out
WoodBoy is offline
post #9 of 42 Old 07-11-2013, 04:58 PM Thread Starter
i did not notice any oil leaking from anywhere but i will also try reading codes with the dashdaq and the ticking was a loud ticking but not like a hard knock like the rocker arm ... the truck should be going to the shop this week i will let you guys know what happend thank you all again
post #10 of 42 Old 07-11-2013, 06:07 PM Thread Starter
Ok so I just took off bottom hose for intercooler and about a quart and a half of oil came out
