Switching from Banks to Spartan and DPF delete - Ford Powerstroke Diesel Forum
post #1 of 6 Old 06-25-2013, 07:36 PM Thread Starter
I'm in the process of putting on a new exhaust and Spartan tuner and just thought of something.
I'd been running a Banks tune. Then I took off my old exhaust. Didn't think of flashing back to stock before I took off the old exhaust. Hope I didn't mess anything up.
So now I have the new exhaust on. All the temp sensors are disconnected, and the pressure sensor as well. I haven't turned the key or started it yet.
I think the order I need to do things is first use the Banks to go back to stock. Then use the Spartan to put on a DPF delete tune.
Am I forgetting anything? What do I do about the sensors? I have them on the old exhaust pieces which are now off the truck, but I could remove them from the old exhaust I think and reconnect them if necessary. Is that even necessary?
Or could I do the process of switching tunes, Use the Banks to go back to Stock then use the Spartan to put on a DPF delete tune with the Sensors disconnected as they are now?
Thanks
Izord is offline
post #2 of 6 Old 06-25-2013, 10:31 PM
Daves05KR's Avatar
The banks six gun tuner, is what im guessing your using, is more of a piggy back type of tuner. It doesn't actually re-tune your ECU it just reroutes everything vs a spartan it completely re-tunes your ECU. You wont have to reuse the banks again, once you unplug the banks tuner your vehicle remains stock so you can actually go straight into loading up the spartan tuner. I hope that helps.
2008 F250 6.4L CC 4x4
Pro-Comp, AFE, EGR Delete, MBRP, Spartan, XD KMCs, Flares, Recon, LEDs, Custom ford badge, Tint, Grote, Pro-Flow, BWS, Chrome Rockers, Fox Racing, 6000K HID Headlights & Fogs, Turbo Sock, CAC, Kenwood, Steel braided brake lines, CCV Mod, BD Diesel Boots, N-FAB
2012 Boss 302 #2528 (Sold)
2005 F250 KR CC FX4 (Sold)
2007 Yamaha R1 (Sold)
2008 Dyna Lowrider (Sold)
Daves05KR is offline
The Following User Says Thank You to Daves05KR For This Useful Post:
Matthewt (07-12-2014)
post #3 of 6 Old 06-26-2013, 06:56 AM Thread Starter
No, I've been using the 66100 programmer from Banks. This one: Banks Power AutoMind Programmer 66100
Izord is offline
post #4 of 6 Old 06-26-2013, 08:47 AM
Daves05KR's Avatar
Yep you will have to reflash it back to stock first before you load the different tunes
post #5 of 6 Old 06-26-2013, 08:48 AM Thread Starter
How about the sensors? Do I need to reattach them?
Izord is offline
post #6 of 6 Old 06-26-2013, 08:54 AM
Daves05KR's Avatar
Nope you do not have to reinstall them, I dont have a spartan personally but ive seen several people run a race exhaust without the sensors attached and it doesn't throw a code.
