Installing 4" Exhaust - Ford Powerstroke Diesel Forum
post #1 of 8 Old 06-18-2013, 11:08 AM Thread Starter
Kenjamin's Avatar
Quoted: 3 Post(s)
I finally am ready to remove my stock exhaust. I have a 4" downpipe back MBRP Bungless DPF/CAT delete exhaust kit. The instructions that came with it tell me that this is a pretty straight forward install. I have read the few exhaust install threads that I could find (although I seem to remember a really detailed step by step thread) and understand the tools needed and what to expect. I am fairly mechanically inclined and am pretty confident that I can do this in an afternoon, maybe into the evening. The few questions I have involve fitment. If I'm correct the stock exhaust is 3.5" but the instructions say that the first section just bolts to the stock downpipe. Is this possible if its going from 3.5" to 4". The next question I have is the kit I got goes all the way to the tip but doesn't include one because I like the look of the stock tip. It says the stock tip can be used but again will I have issues bolting the tip to a bigger pipe. Besides that I think everything else seems pretty straight forward. Everything else I understand from selecting the DPF remove tune on my Mini Maxx, so putting dielectric grease on the disconnected sensors and taping them up out of the way. My kit also has one section of pipe I have to cut because my truck is a crew cab short box. Hopefully many of the guys who have done this can clarify those few things. Also any pointers or links to step by step threads would be awesome. Thanks.
2008 F-350 Harley Davidson Edition
- S&B Cold Air Intake
- Vista-Pro Radiator (Lifetime Warranty)
- H&S Mini Maxx Tuner
- Custom BLACK Ford Oval Emblems
- MBRP 4" Downpipe Back DPF/CAT Bungless Delete With Muffler, Stock Tip
- MBRP 3" Intercooler Pipe
- EGR Deleter Kit With Elbow
- Sinister Coolant Filtration Kit
Kenjamin is offline
post #2 of 8 Old 06-18-2013, 11:16 AM
Echo's Avatar
Yes the 4" exhaust will bolt right to the stock downpipe. But the stock exhaust tip is welded to the exhaust, your not going to be able to just take it off and bolt onto the 4" exhaust pipe.
Echo is offline
post #3 of 8 Old 06-18-2013, 03:27 PM
superduty6.4's Avatar
I had to jack up the rear of the truck to remove the stock tailpipe section. You could just cut it as well if you didn't want to lift it and have no intention of returning to stock setup again.
08 F350 JOB 1
H&S MINI MAXX HD300 W/S1M
SINISTER EGR/COOLER DELETE
6000K BEAMERS HID HEAD & FOGLIGHTS
KMC XD WHEELS W/NITTO TRAIL GRAPPLERS
2.5" LEVELING KIT
DIESELSITE COOLANT FILTER
ROTELLA EC-1 RATED COOLANT
5" DP BACK FLO-PRO EXHAUST
FLO-PRO CAC PIPE & INTAKE ELBOW
CCV MOD
AIR LIFT 5000LB AIR BAGS W/ONBOARD COMPRESSOR
AFE CAI
PMF TRACTION BARS
superduty6.4 is offline
post #4 of 8 Old 06-18-2013, 04:22 PM Thread Starter
Kenjamin's Avatar
Quoted: 3 Post(s)
Good to know. I don't mind cutting anything that is stubborn to get it out. The only thing I want to save is the Tailpipe. I guess Ill have to get it re welded onto the end at a fab shop after I'm done. I don't plan on ever turning it back to stock. I'm contemplating whether or not to keep or sell off my old exhaust parts. I know of a few places that pay not bad for the DPF filters.
Kenjamin is offline
post #5 of 8 Old 06-19-2013, 12:19 AM
How much for your dpf to 95624, California ?
2009 f250/lariat/crewcab/shortbed/eagle alloy 079's/S&B intake/procomp 6inch lift/work in progress...
Jquick is offline
post #6 of 8 Old 06-19-2013, 12:55 AM Thread Starter
Kenjamin's Avatar
Quoted: 3 Post(s)
I'm not sure, 1st off its still on my truck, only 48k on the truck so far. I'd have to check into shipping. They seem pretty heavy so shipping might be a bit. I'll look into shipping costs so I can get an idea if its reasonable. I'll also check around to see what they sell for, I'm not sure what they are worth.
Kenjamin is offline
post #7 of 8 Old 06-19-2013, 01:28 AM Thread Starter
Kenjamin's Avatar
Quoted: 3 Post(s)
I did a rough quote through Canada Post, Purolator and FedEx and they all came in at just over $100 for ground shipping. That's based on a 70 pound package with rough dimensions. Ford lists the filter at 65 pounds.
Kenjamin is offline
post #8 of 8 Old 06-19-2013, 09:59 PM Thread Starter
Kenjamin's Avatar
Quoted: 3 Post(s)
I wouldn't mind replacing my exhaust tip with the side Duals that come with the Banks Monster exhaust kit. Only problem is they don't sell just the Y splitter and tips. I can track down the tips on Ebay but maybe I could take it to a custom fab shop and they could make one.
https://s3.amazonaws.com/pdp-assets/...jpg?1280282939
Kenjamin is offline
