Head studs - Ford Powerstroke Diesel Forum
post #1 of 10 Old 06-18-2013, 06:12 AM Thread Starter
03slobra's Avatar
Head studs
I have had my 08 for month now and am disgusted with 10 mpg. I am having a 4 inch turbo down into a 5inch straight pipe, airdog 165 or fass titanium 150 (haven't decided yet) , sinster egr cooler delete, sinster coolant filter kit, spartan (275 tune) and a deep trans pan put on. My question is, my cab will be off should I do head studs while the cab is off? I really don't want to spend the extra money but I mean if I need to do head studs I will.
My truck is my dd and I just want it to be reliable. I tow about 15 times a year and I don't really get on the throttle that much. As you can tell by my s/n I own an 03 cobra that I beat on so I don't really care about beating on the truck. I just know from racing my cobra that s*** breaks and I know every now and again I will lay into the throttle on the truck. Just wanted everyone's thoughts.
03slobra is offline
post #2 of 10 Old 06-18-2013, 06:32 AM
superduty6.4's Avatar
If the cab is already coming up then I would definitely do it.
08 F350 JOB 1
H&S MINI MAXX HD300 W/S1M
SINISTER EGR/COOLER DELETE
6000K BEAMERS HID HEAD & FOGLIGHTS
KMC XD WHEELS W/NITTO TRAIL GRAPPLERS
2.5" LEVELING KIT
DIESELSITE COOLANT FILTER
ROTELLA EC-1 RATED COOLANT
5" DP BACK FLO-PRO EXHAUST
FLO-PRO CAC PIPE & INTAKE ELBOW
CCV MOD
AIR LIFT 5000LB AIR BAGS W/ONBOARD COMPRESSOR
AFE CAI
PMF TRACTION BARS
superduty6.4 is offline
post #3 of 10 Old 06-18-2013, 07:53 AM
^^^^Agreed....when the cab comes off the studs go in.
2010 Ford F-250 Super Duty, Lariet 4x4, Crew Cab Short Bed, loaded with every option...and more
turbo kidd is offline
post #4 of 10 Old 06-18-2013, 09:04 AM
WoodBoy's Avatar
If you dont want to spend the money take the LPFP off the list for the time being and do the studs instead. Also a CAI would be a good investment. Question is why is the cab coming off in the first place?
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #5 of 10 Old 06-18-2013, 11:11 AM
I'm going to be the newbie and ask the question. What exactly are the studs and the positive to replacing them?
jacobshain is offline
post #6 of 10 Old 06-18-2013, 11:24 AM
Texas Proud
charlie.thomas's Avatar
I'd do the studs as well as the others said, will benefit you in the end. Sooner or later you would half to decab again and then you would technically be paying almost double the labor when you could do it now. I'm curious also, why is the cab coming off?
"Feel the Fear and Do It Anyway"
2007 F250 King Ranch
Alligator Performance EGR Delete
5" AFE air intake
Blue Spring Mod
High Idle Mod
4" Turbo back straight exhaust
SCT Livewire TS tuned by the best, "Tony Wildman"
New block bored .020" over
New heads ported, polished, and decked
ARP Head studs
And other goodies
Lifted on 35" Toyo Open Country MT
charlie.thomas is offline
post #7 of 10 Old 06-18-2013, 11:30 AM
ars5147's Avatar
Quoted: 124 Post(s)
If you are looking to not spend any extra money, don't lift the cab. All of what you said you don't need to lift the cab to put on. DP, EGR delete, coolant filter all can be done cab on. Unless there is some other reason for lifting the cab, it doesn't need done.
If this is all being done at a shop and not by you, they are taking your money that you don't need to spend.
If the headgaskets are not leaking, then don't mess with studs and lifting the cab. At that tuning level you should be fine. Many people with 6.4s are running H&S and Spartan canned tunes with stock head bolts. Do studs if you ever encounter a blown HG down the road.
That should save you some shekels.
2008 F250 CCSB 6.4
1997 F350 CCLB 7.3
2011 F150 SVT Raptor
ars5147 is offline
post #8 of 10 Old 06-18-2013, 04:14 PM Thread Starter
03slobra's Avatar
Thanks for the info, the shop was thinking about yanking the cab off to do the egr coolers because it would be easier. I talk to them today and they decided there going to leave the cab on so looks like I won't be doing head studs. The truck already has a cai.
03slobra is offline
post #9 of 10 Old 06-19-2013, 08:45 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Yea I wouldn't pull the cab to do an egr delete.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #10 of 10 Old 06-19-2013, 08:52 AM
Texas Proud
That'd be senseless to pull the cab for a egr delete
5" AFE air intake
Blue Spring Mod
High Idle Mod
ARP Head studs
And other goodies
