My dyno # dont seem to be right. - Ford Powerstroke Diesel Forum
post #1 of 13 Old 06-17-2013, 04:13 PM Thread Starter
19$MBR$95's Avatar
So i went to a dyno competition last week and decided to run my truck. The crazy thing is all i have done is a H&S blackmax intake and exhaust. The first run was 653.5 HP and 1394.4 TQ the second run i put in tow haul and it ran 682.1 HP and 1359.3 TQ. Now i ended up winning the stock class by over 50 hp second place was another 6.4 that hit 630 hp. Needless to say everyone was dumbfounded and thought i was cheating naturally but that is seriously all i have done and they swear that the dyno was correct.
2003 F350 CCSB 6.0 Leveling kit 35" Nitto Trails, 20's, Straight pipe. SCT X3 innovative tunes, S&B Intake. Banks Techni cooler.
1995 F250 SCLB 7.3 DIY 6637 Intake, 3" DP 4" DP back straight pipe, shimmed FPR spring, stock Acola wheels.
1994 Mustang GT 347 stroker trickflow heads and manifold. BBK Longtubes BBK H pipe Flowmaster super 40's mufflers. Nitto NT55 Drag radials. ZEX 150 wetshot.
2010 F250. some fun stuff done.
680.3 HP
1357.8 TQ
19$MBR$95 is offline
post #2 of 13 Old 06-17-2013, 04:35 PM
08stroker250's Avatar
My guess is that it was a SUPER forgiving dyno and the numbers were HEAVILY corrected. Tuner only 6.4's typically make between 550-580 horsepower (give or take 10), and that's track proven. Anything over 600 horsepower with stock fuel (and fuel only) is going to require more air (turbo upgrades) to be legit.
Jeff Dodd
2012 Ford F-250 Lariat CC/SB
Mods - Spartan tuned via laptop, 4" AFE stainless exhaust system, 2.5" PMF BMC leveling spacers, 3" PMF lift blocks, Fox Racing 2.0 shocks, Recon smoked mirror & cab lights
08stroker250 is offline
post #3 of 13 Old 06-17-2013, 06:16 PM
Jeff mine did 630 and I swear by it. Its probably not right but really helps my low ego and the fact that I'm driving a ford.
Trouble maker is offline
post #4 of 13 Old 06-17-2013, 07:46 PM
BIG Laing's Avatar
I found this funny... Not in a bad way. Just gave me a chuckle to have a range and a tolerance.
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #5 of 13 Old 06-17-2013, 07:56 PM
Yeah, your numbers are a bit on the high side my friend. Get it to the track! That'll tell the tale!
Let me explain. There are multiple tuning companies with tunes out for the 6.4L. Not every company produces the same numbers. There is also the simple fact that not every truck/engine is the same. You could run identical trucks on the same dyno back to back, with the same tuning, and there may be a 10-15 horsepower difference. Then you have to factor in tire size. The bigger the tires, the less horsepower the truck will put to the ground. And finally, tuning has been out for the 6.4L for a long time. In general, race tunes show anywhere from 550 up to 580-590 at the track using a horsepower calculator based on vehicle weight and trap speed. Some dyno's back this up and others read either way high or way low. This is why dyno's should NEVER be used to determine the true horsepower of a vehicle. They're a tuning tool. Start with a baseline, and go from there.
An example of extremes with dyno's.....I put my truck on the Dynocom at Rudy's Diesel Performance and my truck made 640 horsepower with stock turbos fuel only. 12 hours later my truck went on David Dunbar's mobile Dynojet 248C and made 594. No changes at all. Two different dyno's, same truck, 12 hours apart on the runs.
Jeff Dodd
post #6 of 13 Old 06-18-2013, 10:09 AM
WoodBoy's Avatar
What is funny about those numbers? Jeff is very correct. Track times prove it. OP, I would agree that the correction factor was turned way up on the dyno.
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #7 of 13 Old 06-18-2013, 10:15 AM
JUGGS's Avatar
It's because usually you get EITHER a number with a plus/minus, OR a number range. Seldom see both together.
Edit ** it has nothing to do with the topic...just an observation (it made me chuckle too) **
2005 F250 Lariat CCSB/170k mi./6sp Handshaker
Don't Worry
Dieselsite coolant filter, CAT ELC, Bulletproofed and monitored by BPD
Be Happy
SCT SF3, 4" Flo Pro, 2.5" Readylift SST, 35" GoodYear Fierce Attitude M/T's
JUGGS is offline
post #8 of 13 Old 06-18-2013, 01:50 PM
Those numbers do seem pretty high, our truck made 582 HP and 1287 ft lb to the wheels here at our shop, 2780 ft elevation. Jeff is absolutely correct, aside from different dynos/operators every truck will respond to tuning differently.
Ford 6.4L Powerstroke Dyno Results | Diesel Performance Tuners
H&S Support is offline
post #9 of 13 Old 06-18-2013, 09:46 PM
BIG Laing's Avatar
This is why I chuckled Woodboy. I work with blueprints and sketches everyday...
Thanks Jeff for your explination.
post #10 of 13 Old 06-19-2013, 04:36 PM
Quoted: 45 Post(s)
A dyno operator can make the numbers come out to be whatever he wants.... Especially if it is one of the Dynojet models...
2015 F350 DRW Platinum, SCT X4, EDGE CTS2, aFe PDS, AirLift 5000 Ultimate & Wireless Air, Lund LED Bull Bar, RC Grille bar, B&W 5th Wheel, Stark LED Lighting
2010 F250, H&S Mini Maxx, aFe PDS, Diamond Eye 4", Pro Comp Nitro 2.5", Bilstein 5100, SmittyBilt Bull Bar, Bushwacker Pocket Style, B&W Slider, Firestone Ride-Rite, Fuel Hostage 20x10, Pioneer/Kicker/JL Audio
RUFFSTUFF is offline
