Need advice - Ford Powerstroke Diesel Forum
post #1 of 5 Old 06-17-2013, 06:20 AM Thread Starter
hyrczyk's Avatar
Need advice
I am finally able to afford to order a tuner for my 08 F250 that has 71k on it. Not looking for a high hp tune just wanting to make the truck last so I'm looking at the H&S MM race tuner from PTP.
A few questions I had are as follows.
-Do I need to remove the egr set up or can I leave it turned off for time being? (have very limited funds and time at moment do to family health issues)
-Will just putting a dpf delete pipe on from flo-pro be sufficient until I can afford my duals I want?
-How much is gained by running a cold air intake with this setup?
hyrczyk is offline
post #2 of 5 Old 06-17-2013, 07:16 AM
superduty6.4's Avatar
You can leave the EGR delete installed until funds allow removal. The mild and hd300 tuning disable the EGR system whether its installed or removed.
Yes a delete pipe will work fine until you are ready to do the rest of the exhaust.
Not to sure on the CAI question because up until about 2 weeks ago I was just running a drop in afe filter. I will see if there is any benefit towing this week when we go on our holiday pulling the camper. Realistically the more air that the engine can get the happier it should be but I guess it really depends on how you use the truck. I use the drop in filter with 0 issues and only upgraded because I got the CAI for a good price.
08 F350 JOB 1
H&S MINI MAXX HD300 W/S1M
SINISTER EGR/COOLER DELETE
6000K BEAMERS HID HEAD & FOGLIGHTS
KMC XD WHEELS W/NITTO TRAIL GRAPPLERS
2.5" LEVELING KIT
DIESELSITE COOLANT FILTER
ROTELLA EC-1 RATED COOLANT
5" DP BACK FLO-PRO EXHAUST
FLO-PRO CAC PIPE & INTAKE ELBOW
CCV MOD
AIR LIFT 5000LB AIR BAGS W/ONBOARD COMPRESSOR
AFE CAI
PMF TRACTION BARS
superduty6.4 is offline
post #3 of 5 Old 06-18-2013, 02:03 PM Thread Starter
hyrczyk's Avatar
Thanks for the info. Truck is used as a daily driver and to tow our fishing boat and snowmobiles.
hyrczyk is offline
post #4 of 5 Old 06-18-2013, 09:23 PM
fr9090's Avatar
Quoted: 4 Post(s)
I have a banks CAI. On mine abd there was a noticeable difference. Worth the money when u can swing it
fr9090 is offline
post #5 of 5 Old 06-22-2013, 12:04 PM
Fueling M.A.D. Everywhere
CountryAggie's Avatar
Congrats on taking the plunge. The tuner can turn off the EGR, so don't worry about that until your funds are available. The delete pipe will work just fine (I ran mine with just a delete pipe for almost a year). Only thing you will gain with the CAI is not pulling in the filter minder every time you accelerate on a high HP tune (the hotter tunes move a lot of air), but a drop in will also fix this for cheaper than a CAI.
-Tyler
Texas A&M c/o 2010
CountryAggie is offline
