Anyone ever used the Gear Box Z Tachyon Plus Programmer? - Ford Powerstroke Diesel Forum
 8Likes
post #1 of 56 Old 06-14-2013, 10:57 AM Thread Starter
chardnay10's Avatar
Has anyone ever used this tuner before? HOw much more power do you notice? and this is with dpf delete.
chardnay10 is offline
post #2 of 56 Old 06-14-2013, 12:00 PM Thread Starter
chardnay10's Avatar
nevermind i found my answer.
post #3 of 56 Old 07-12-2013, 10:17 AM
soundmandave21's Avatar
So what was the answer? I am trying to find the HP gain as well
1997 4x4 F-250 Xcab LB, ChildSeat
soundmandave21 is offline
post #4 of 56 Old 07-12-2013, 12:37 PM Thread Starter
chardnay10's Avatar
with the 5 power level one the horse add is 150hp
post #5 of 56 Old 07-12-2013, 12:49 PM
I contacted vendors and they said there were no published values and I have yet to hear back from the manufacturer. Did you purchase one of these tuners for your truck? Any feedback?
post #6 of 56 Old 07-12-2013, 02:05 PM Thread Starter
chardnay10's Avatar
I called the company that makes it and a tech said that they were designed to add 150hp but he said it hasnr been dynod so hes not 100% sure but when they test drove it he said its around 150 thats all I heard from him
post #7 of 56 Old 07-12-2013, 08:42 PM
Fueling M.A.D. Everywhere
CountryAggie's Avatar
The man must have a damn calibrated butt dyno!!
Sent from AutoGuide.com App
pops250 and peripheralthinker like this.
-Tyler
Texas A&M c/o 2010
CountryAggie is offline
post #8 of 56 Old 01-06-2014, 06:52 PM
imk0001's Avatar
I actually just put one of these on my truck and I'm not really sure at how much more power it gave it. It definitely woke it up and it sounds awesome. I've heard other 6.4s that were straight piped and for some reason, mine just has more of a 6.0 sound to it. Also, I noticed that it elevated my idle RPMs as well. Before they were between 650 and 750. Now they're 950ish. Anyone else know if this is normal?
imk0001 is offline
post #9 of 56 Old 01-06-2014, 07:09 PM
Quoted: 2 Post(s)
You need to plug the egt sensors back in and the pressure sensor to your harness. They don't need to be in the exhaust. Just plugged in and zip tied to the frame rail. That's what's causing the high idle.
Kris
2008 Ford F250 6.4L Crew Cab Short Bed King Ranch
3.5" ReadyLift Leveling Kit, 37x13.5x20 Toyo MT's on stock 20's, Dual Steering Stabilizer, Livewire w/ IDP, KEM, Gearhead, S&B, 5" Flo-Pro, Rudy's EGR Delete and Cold Side Pipe, CCV
p8ntballn2 is offline
The Following User Says Thank You to p8ntballn2 For This Useful Post:
imk0001 (03-17-2014)
post #10 of 56 Old 01-06-2014, 07:20 PM
imk0001's Avatar
Okay thank you. How much does ford charge for an EGT sensor. I want to get another set so I can just leave the old ones in the DPF.
imk0001 is offline
Tags
dpf delete , tuner
