late lock vs. early lock - Ford Powerstroke Diesel Forum
post #1 of 11 Old 06-11-2013, 03:47 PM Thread Starter
Hey guys! I'm kinda new to the diesel truck scene and I spartanized my truck and I'm wondering which is better for a daily driver. I don't do a lot of highway but will be doing some when we go camping. Right now I am running 210LL.
Quatris is offline
post #2 of 11 Old 06-11-2013, 03:50 PM
Warheads on Foreheads
superdutydixie's Avatar
I used to drive mostly city with H&S, so I had mine set to lock in 4th at 35mph and lock in 5th at 50 mph. Gave me the best mpg but now I drive a mix so I only have it lock at 50 mph in 5th gear. Not sure if that helps since I don't have spartan
09 F-250 Superduty CCSB
SOLD
superdutydixie is offline
post #3 of 11 Old 06-12-2013, 11:35 AM
What ate your gears in the rear 3:55 if so use EL.
MobyS is offline
post #4 of 11 Old 06-12-2013, 05:48 PM
WoodBoy's Avatar
I would also use EL
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #5 of 11 Old 06-12-2013, 09:59 PM
I have 3.55 gears on a 2010 and use LL. Have tried both, but always go back. Suggest you try both as well and pick what works best for you.
2010 F250 CC 4x4 Lariat FX4, Spartanized,
dgiles is offline
post #6 of 11 Old 06-13-2013, 05:59 PM Thread Starter
I'm not 100% positive but I think I have 3.73 gears in mine.
Quatris is offline
post #7 of 11 Old 06-13-2013, 07:36 PM
I have actually never tried LL so like the other poster suggested try both and you decide what you like best..
I have always seen Jeff from Spartan suggest EL with 3:55 gears... At least I think so ,now I am second guessing myself...
MobyS is offline
post #8 of 11 Old 06-13-2013, 09:07 PM
Clayton1985's Avatar
I use both but prefer early. I have 3.73 with 35'' tires.
Try both, I think youll prefer early but ya never know, nice to have options!
2008 Job 3, F350, 6.4/drw/lariat/CC/LB, Spartan, Viper 5902, Line-X, Flo-pro egr delete, aFe stage 2 proguard 7, MBRP Cool Duals/downpipe/CAC, CCV mod, coolant filter PMF 7" 4link, Rigid Dually fogs, Royalty Core 3pc, Crown brake lines, Mishimoto Rad
6.4 Rebuild May/2015, BD manifolds+Uppipes, chromoly rods, rockers,lifters, hd springs
Monstir 20", 37x12.50 ATZ P3
1999 Corvette Cpe
Clayton1985 is offline
post #9 of 11 Old 06-14-2013, 09:05 AM
08twinturbo's Avatar
After trying all of them. I can tell you what is quickest and best gas mileage for me. Thats the s1l early lock in 4th&5th.
08twinturbo is offline
post #10 of 11 Old 06-14-2013, 09:44 AM
Hunter of Trolls
drewactual's Avatar
Quoted: 58 Post(s)
what you're doing should determine what schedule you should use... I reckon it could come down to a preferential thing, but the only time that is reasonable, in my opinion, is if you're using your rig right at the 'swing' point between the two major functions...
mechanically speaking:
the torque converter, while LOCKED, physically connects the input shaft and the engines crank.. the workload is directly on the engine...
the torque converter, while UNLOCKED, allows the crank to spin faster than the input shaft of the transmission is spinning- some people use the term 'torque amplification', though that isn't exactly what's happening.. it's more along the lines of 'inertia amplification'....
think of the UNLOCKED t/c as an arrow and the LOCKED t/c like a bullet.. the bullet strikes a target and the target instantly negotiates and absorbs the energy in whole.. an arrow strikes a target and the target absorbs the energy from the tip, just like a bullet, but then it has to absorb the energy from the shaft, and then the end- which means the arrow has more penetrating power, and also (more in line with why I present it as an illustration), it has more INERTIA behind it- it's harder to stop..
put that in drive terms:
if you're approaching a hill with the converter locked, the EGT's are going to climb as the engine alone has to produce the need for added torque as that hill's incline depletes the torque it's already producing.. it may or may not be capable of doing so.. with the extra leverage provided by an unlocked t/c, that grade may not be able to deplete all the inertia stored up in the t/c..
put that in real world terms:
the t/c UNLOCKED produces energy you may not be needing, which is expelled in terms of heat.. if you don't need the energy/inertia, you're going to be making excessive heat- heat is enemy #1 for transmissions, but it will make the engine happier.. The t/c LOCKED reduces the transmissions heat, and will make a transmission last longer- but will transfer the workload more towards the engine and it's components, which is much harder on engines, but will make a transmission happier..
you gotta strike the balance based on what you are doing with your rig.. select the higher lock higher shift schedule when racing about, or pulling loads/hauling cargo.. use the lower shift lower lock when daily driving loads the engine can handle.. basically, if you find yourself using the tow/haul feature often, then you are a likely candidate for using the higher shift/lock schedule.. if you rarely use it, then you (and your transmission and engine) are going to be better off with the low shift/low lock schedule..
one more thing: monitoring the EGT's is the tell tale sign.. just for fun, and to prove my point, next time you are driving unloaded and at a steady speed of say, 55mph, locked t/c and 5th gear, reach up and pop off the o/d.. you'll watch your RPM's kick up a few hundred digits, but you'll watch your EGT's lower... why? less strain on the engine using the better leverage of the lower gear... that is a perfect example on a more visible scale of the balancing act between locked and unlocked and how the work load shifts between the transmission and the engine..
edited to add: our rigs, as delivered from the factory, have a hugely wide torque band (over 1k RPM's wide).. unless you want to race around, or unless you are pulling/hauling weight in excess of 1/4 the rigs capacity, your engine and trans are going to appreciate the shifts and the t/c locking up sooner.. your wallet in terms of fuel costs are going to like you better too.. if you are all about getting maximum torque to the terra as you would be in racing about, or truly working your rig- you're going to benefit from late shift/locks..
drewactual is offline
