Not sure what this is. - Ford Powerstroke Diesel Forum
post #1 of 18 Old 06-06-2013, 04:17 PM Thread Starter
SySx's Avatar
Still learning about the 6.4 but this is dripping oil. What is it and how can I make it stop thanks.
93 Chevy Blazer R.I.P. Baby
03 Ford Lighting 500 hp SOLD
09 Dodge Challenger R/T SOLD
03 Ford F350 Crew Cab 4x4 SOLD
08 Ford F350 CCLB Dually Mini Maxx Race Tuner, Turbo Back Flo Pro 4" straight pipe dual exhaust
SySx is offline
post #2 of 18 Old 06-06-2013, 10:16 PM
NVHunter83's Avatar
08 Job 1 truck? Looks like the external transmission filter. My trucks a job 2 so it doesn't have the external filter, just internal.
2008 Ford F-350
6.4L Power Stroke
Crew Cab Long Bed
Buck Stop Bumper w/
WARN 9500 lbs. Winch
H&S Mini Maxx w/ homemade mount
5" Flo-Pro DPB exhaust w/ muffler
Bilstein 5100s Shocks
AFe Stage II Magnum Force Intake
NVHunter83 is offline
post #3 of 18 Old 06-07-2013, 04:49 AM
Yeah it's a Turbo Diesel
mts678's Avatar
Quoted: 7 Post(s)
Feedback Score: 12 reviews
That's exactly what that is but the oil isn't dripping from that. You either have a glowplug seal leaking, bedplate leaking (oil pan gasket- 3 total) or rear main seal leaking. If its rear main, pop that little black grommet out on the bell housing right above the tranny filter and if there's oil all up in there then it's a rear main seal. It also could be the sensor above the front cover on driver side leaking as that is a common leak
Sent from AutoGuide.com App
Marshall
2002 F250 7.3L CCSB 4WD
Tinted | Focal speakers & 12" Kicker | CTS Insight | CNC fuel line kit | PIS 200/80's | KC38R | Nathan P3 train horns & Onboard Air
mts678 is offline
post #4 of 18 Old 06-07-2013, 05:20 AM Thread Starter
SySx's Avatar
You wouldn't happen to know the cost on giving each of those would you?
SySx is offline
post #5 of 18 Old 06-07-2013, 05:24 AM
mts678's Avatar
Quoted: 7 Post(s)
Bedplate seal replacement requires cab off or tranny out. Labor was $2200 under warranty and the parts were like $150. Glow plug seal replacement was like $150- requires a new glow plug harness- but I paid my tech on the side since I know him. And that other sender by the front cover I remembered its the CAM sensor, he did it on the side for $50- with a good light u can see it through the driver fender well area by the belt.
Marshall
mts678 is offline
post #6 of 18 Old 06-07-2013, 05:28 AM Thread Starter
SySx's Avatar
What about the rear main seal? I'm guessing most of these can't be driveway fixes?
SySx is offline
post #7 of 18 Old 06-07-2013, 05:30 AM
mts678's Avatar
Quoted: 7 Post(s)
Look at each valve cover and check the glow plug seals, Check for the cam sensor, and pull that rubber grommet out on the bell housing and check for rear main seal and look around the oil pan joint
Marshall
mts678 is offline
post #8 of 18 Old 06-07-2013, 05:32 AM
mts678's Avatar
Quoted: 7 Post(s)
I have no idea about the rear main, I'm pretty sure it requires tranny out which is a biatch in the driveway. I've never torn out a 4x4 tranny with transfer case so I have no idea. I have removed several 2x4 trannies and it was a biatch lol.
Marshall
mts678 is offline
post #9 of 18 Old 06-07-2013, 05:37 AM Thread Starter
SySx's Avatar
Seriously about to call the dealership and return this truck, I love it but not worth the headache it's been in just a week.
SySx is offline
post #10 of 18 Old 06-07-2013, 07:21 AM
mts678's Avatar
Quoted: 7 Post(s)
Do u have any warranty on it?
Marshall
mts678 is offline
