Tire size calibration ?s - Ford Powerstroke Diesel Forum
post #1 of 8 Old 06-06-2013, 02:58 PM Thread Starter
F250Marine's Avatar
I did a search looking for the answers I need and came up with nothing definitive. I'm running the spartan tuner and am getting ready to install my lift. I'm going to be running 35's. I know that I can't re calibrate my speedo with the dash daq. What I'm thinking is going to the dealer putting the truck back to the stock tune, unplugging the Dd and letting them set my tire size then reinstalling my delete tunes. Am I on the right track or is there an easier way to do this? Any help would be awesome!
2008 F-250 Ext. cab FX4, Spartan tuned 300 EL, S&B intake, 4''DP, 5" flo-pro straight exhaust w/ black 6" MBRP tip.
Coming soon 4.5" Rough Country Lift w/ 18" Ballistic Jesters wrapped in 35X12.5 Nitto Trails
F250Marine is offline
post #2 of 8 Old 06-07-2013, 03:24 PM Thread Starter
F250Marine's Avatar
Bump anyone have some help with this?
post #3 of 8 Old 06-07-2013, 07:50 PM
I herd if you know someone with a H&S tuner they can do it for you,Im looking for someone in the carson city, Reno, lake table area.
Pete
frusteri4 is offline
post #4 of 8 Old 06-11-2013, 11:33 AM Thread Starter
F250Marine's Avatar
Yea the only guy I know with an h&s has a Dmax not sure if that will work. Hopefully someone else will jump in soon.
post #5 of 8 Old 06-11-2013, 11:52 AM
floorboy's Avatar
I believe you can do it with an auto enginuity too. Maybe check the 7.3 forum for somebody close. I would but no where close.
Originally Posted by bjs505 View Post
Of course I'm handy under the hood, I currently own a cummins.
2010 F350 CCLB Cabelas Edition
No Limit cai, Mini Maxx, 5" turbo back Flo Pro, Sinister egr delete, Sinister coolant filter, Cat EC-1, PTP shift solenoid. 20x9 +18 XD Monsters
01' 7.3 CCLB, 6637,wicked wheel G2, HPX, PHP Hydra, MBRP 4" Turbo back, Bellowed uppipes, Stancor gpr, 6.0 cooler, Fpr, Glow shift exhaust, pyro, trans, 203*/billet housing/ Cat EC-1, '07headlights/05' grill, Oh8' gate.
78' F350 "dumpy" old school
floorboy is offline
post #6 of 8 Old 06-11-2013, 12:50 PM
42Superman's Avatar
I would love to get this done also.
Spartan Tuned -Running the 275HP
S&B Cold Air Intake
DPF Delete
4” MBRP Exhaust
10” Rize Lift with Traction Bars
Fabtech Dirt Logic 2.25 Dual Shocks Front & Rear
Fabtech Dirt Logic Dual Steering Stabilizer
Flo-Pro EGR Delete with Intake Elbow
Flo-Pro Intercooler pipe
CCV Mod
8000k HID’s High / Low and Fogs 55watt
20” x 12” Fuel Octane’s with 40” Toyo MT’s
42Superman is offline
post #7 of 8 Old 06-12-2013, 05:47 PM
WoodBoy's Avatar
Ive heard of people doing the tire pressure sensor block thing from H&S using an H&S to install it or whatever but then running Spartan tunes with no problem. Honestly, there is very little difference between stock and 35s that I wouldnt worry about it
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #8 of 8 Old 06-12-2013, 06:04 PM
DirtyDiesel's Avatar
Quoted: 3 Post(s)
i went down both of these problem paths wiht my truck and spartan
when i went to my 33s/20 i didnt swap over my tire sensors. i had to get the H&S TPMS module from a fellow member on here and find somebody dow here with an H&S tuner that i could use to disable the TPMS. craigslist worked awesome, just find someone wanting to sell a tuner, lol. was just a pain because i had to return my truck to stock (20min), load up the H&S tuner (20min), return to stock (15min), then reload my spratan to get home (20+min). but it did turn off the TPMS totally.
HOWEVER when i was using the H&S tuner i also tried to recalibrate the speedo for the smaller (33 vs 34) but it DID NOT carry over the calibration after i changed back to spartan. i ended up gon gto ford to get them to recalibrate the ABS module. FYI you DO NOT have to remove youre tuner to have ford recalibrate youre speedo. i was talkignt o the tech and he hadnt done the tire size change on a modded truck so he had me return mine to stock but later said i didnt need to. cost me 75 bux.
Brett
'08 Ford F-350 Powerstroke Lariet 4x4
SPARTAN Tuner, Flo-Pro 5" Exhaust 6" Tip, Deleted, S&B Intake, B&W Hitch, 2.5" Leveling kit, Custom Rear Traction Bars, 20x12 FUEL NUTZ, 33x12.5 Toyo MT's, PIONEER Screen, 3500W of ORION amps, Sundown SD3 10" subs, Blacked out Headlights, Retro LED bulbs, Recon Mirror Lights
DirtyDiesel is offline
