Up-pipe delete and/or upgrade ? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 06-05-2013, 02:54 PM Thread Starter
Big_Smokey's Avatar
Quoted: 8 Post(s)
I came across a thread where it mentioned getting rid of one of the up-pipes. I havent been able to find any other info on this topic. Just curious if i could get some assistance. I removed all the egr stuff also as i read that will determine if you can do this or not.
What has happened is i have a hissing noise, to what sounds like the drivers side. Its the loudest when i first take out of the road cold. then after it warms up its not as bad. I was going to guess a leaky up pipe or one of my boots may be loose or cracked. Im getting ready to go look now for some sooty areas. If you can delete it and block it off id rather do that and not have to worry about it cracking again if it happens to be the an up-pipe.
Also. H&S tunes dpf/egr deleted as well.
Big_Smokey is offline
post #2 of 9 Old 06-05-2013, 05:47 PM Thread Starter
Big_Smokey's Avatar
Quoted: 8 Post(s)
I looked on the drivers side, i could see it, but i really need a flashlight....started raining again! So i gave up. the bellows, is that what they are called.......are shiny and clean. I did notice on the drivers side of the transmission and i followed it upward a ways and it was black...
anyway thats all i got, i hope someone has something on the delete option of the up pipe
post #3 of 9 Old 06-05-2013, 07:32 PM Thread Starter
Big_Smokey's Avatar
Quoted: 8 Post(s)
anybody yet.
post #4 of 9 Old 06-05-2013, 07:40 PM
montana6.0's Avatar
If its the pipe that runs into the egr cooler you can take it off but you have to do egr delete and then put the block off plate up top behind the turbo where it connects then would have to tap the plate for your ebp sensor. That's the only pipe I've heard of this being done. Hope it helps and maybe someone that's done it will speak up.
2010 F350 auto
2inch leveling kit
35'' toyo m/ts
20'' montsers
dpf cat delete
h&s mini Max
s&b cai
montana6.0 is offline
post #5 of 9 Old 06-06-2013, 08:41 AM
I've done it. It's a fairly difficult process, but it was definitely worth it for me.
My 6.4 EBP sensor relocation
B. Adams is offline
post #6 of 9 Old 06-06-2013, 05:00 PM Thread Starter
Big_Smokey's Avatar
Quoted: 8 Post(s)
My EGR crap is all gone. So if its that pipe that is cracked it can go bye bye then. alrighty i guess ill see what the doctor says about it.
Bryan I like the pics and write up. So if i get this right. after you removed the up pipe from the truck you plugged both the up-pipe holes with the same type of plugs as were used in the EGR delete process. Then in the upper one you drilled a hole in the center of it and threaded the hole.....etc..etc. to get the sensor to connect to this location. Looks like it wouldnt be as hard to do as pulling the cab or dropping the tranny to put in a new pipe! If thats what it ends up being im pretty sure i will be doing this.....However my dealership is pretty cool with mods and im still under engine warranty.....But id just assume to never have to worry about this again
post #7 of 9 Old 06-06-2013, 06:29 PM Thread Starter
Big_Smokey's Avatar
Quoted: 8 Post(s)
i guess i dont need the egr plugs, but the regular exhaust block of plates without the o-rings...whoops my mistake
post #8 of 9 Old 06-06-2013, 10:16 PM
You're basically correct. I removed the pipe that used to feed the EGR, drilled and tapped the plate that was blocking off the end of that pipe, and put it where the pipe I removed had been connected. The joints are both the same size.
It's hard, but it's not as hard as removing the EGR in the first place. It would also be a lot easier if you had someone helping you. I did it all by myself, which made some parts of the process really difficult.
If you have an EGR delete already, you already have most of the pieces you need to do this. You can do it all with the existing pieces, actually, but I'd recommend using a different fitting to attach the EBP sensor than the stock fitting and steel tube. I used different fittings and got the sensor in what I think is a good place, and I'm really happy with the results. If you were going to copy me exactly, you'd need 2 flare fittings, some copper wire, heat shrink tubing, some cable wrap, and electrical tape. And the ability to solder. The only unusual part of the deal is the flare fittings for the sensor, which you're unlikely to find locally. Everything else is run of the mill hardware store stuff.
B. Adams is offline
post #9 of 9 Old 06-07-2013, 07:39 PM Thread Starter
Big_Smokey's Avatar
Quoted: 8 Post(s)
Oh yah...duh i forgot i already have a block of plate on that pipe already down low....alright.... I was debating on seeing if i could find the correct fitting for the sensor and have my buddies dad weld it together. Hes a retired welder of 40 years and can weld any metal....Soldering ive done before when i was in tech school, but its been A WHILE!!
Thanks bryan, id say ill be doing this in the next week or so
