EGR Delete, What else? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 06-05-2013, 05:29 AM Thread Starter
CowboyCody's Avatar
I think my EGR is Leaking coolant, so i plan on deleting it soon. is there anything else i should do at the same time? i plan on doing a coolant flush and switching to ELC along with a coolant filter. Should i change the thermostats while i am at it? Do they go bad that often? Anything else that makes sense to do at the same time?
Originally Posted by madpowerstroke View Post
Try spinning a turbo with compressed air and hit it with diesel clean as you inhale at the turbo outlet, I call it a turbo bong.........that's some good stuff, makes you come up with all kinds of crazy ideas.
2010 F450 Super Duty Lariat Ultimate, 140,xxx Miles. 5" DP Back. Black Maxx. AFE Pro 5R Stage 2. ARP studs new heads and gaskets.
CowboyCody is offline
post #2 of 10 Old 06-05-2013, 05:51 AM
superduty6.4's Avatar
I would do the thermostats while you are in there.
08 F350 JOB 1
H&S MINI MAXX HD300 W/S1M
SINISTER EGR/COOLER DELETE
6000K BEAMERS HID HEAD & FOGLIGHTS
KMC XD WHEELS W/NITTO TRAIL GRAPPLERS
2.5" LEVELING KIT
DIESELSITE COOLANT FILTER
ROTELLA EC-1 RATED COOLANT
5" DP BACK FLO-PRO EXHAUST
FLO-PRO CAC PIPE & INTAKE ELBOW
CCV MOD
AIR LIFT 5000LB AIR BAGS W/ONBOARD COMPRESSOR
AFE CAI
PMF TRACTION BARS
superduty6.4 is offline
post #3 of 10 Old 06-05-2013, 06:29 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
I would also change the t stats. Also if your radiator hoses arent the updated ones might as well get the updated hoses while you are draining the coolant. Also if you have the money the CAC pipe.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #4 of 10 Old 06-05-2013, 08:00 AM Thread Starter
CowboyCody's Avatar
yeah i would like to do the CAC pipe also but im not sure the wife will go for it what about the updated degas bottle i have been reading about? is it worth the effort to change?
post #5 of 10 Old 06-05-2013, 08:01 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
The updated degas bottle only has one port and updated fill lines.
08 F350 cc/sb 4X4
post #6 of 10 Old 06-05-2013, 08:01 AM
2000-7.3L's Avatar
Feedback Score: 10 reviews
PM me with a list and i can get everything you need including the EGR delete kit!
2000-7.3L is offline
post #7 of 10 Old 06-05-2013, 08:17 AM Thread Starter
CowboyCody's Avatar
Ok, but what exactly is it supposed to do? Is it worth the $ ?
post #8 of 10 Old 06-05-2013, 08:33 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
It doesnt really do anything. It has the fill lines lower so you wont overfill and puke coolant. It also only has one port for the coolant return. I have been wanting to upgrade it but i havent yet. I probably would since you doing all that work to your cooling system.
08 F350 cc/sb 4X4
post #9 of 10 Old 06-05-2013, 08:42 AM Thread Starter
CowboyCody's Avatar
Ok , thanks
post #10 of 10 Old 06-05-2013, 09:53 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
No problem bud! Keep us posted
08 F350 cc/sb 4X4
