H&S Mini Installed now having a battery problem - Ford Powerstroke Diesel Forum
post #1 of 5 Old 05-27-2013, 09:03 PM Thread Starter
I recently installed the mini maxx as the manual stated by powering it off of the purple wire under the dash so it powers up when the ignition is on. I tested the wire before and it shows no voltage until the key is turned. This seems all normal to me and the truck is running great. I had driven the truck about 150 miles before a long trip this past weekend and the only thing I noticed is that every once in awhile I would get an error for the Tire Pressure Monitor Sensors, but it was an intermittent thing.
This past weekend I drove about 400 miles and then I parked the truck for two days. I go to start the truck up and click click... battery is dead. So I jump the truck and it starts up fine. I run it for about 20-30 min and shut it off for a few hours and it starts up fine and I drive to where I'm staying and park it overnight. This morning I go to start it and it does start but it's labored meaning the batteries sound drained but it has enough juice to start. I unplugged the mini overnight just in case it might have a slow drain from there as I have not done anything to the truck besides the delete, install mini, and s&b cai. Well after I get the truck started I switch the display menu to show voltage for the battery and I got consisten 14.0-13.8 volts all the way home for 400 miles. Is that the right voltage that I should be seeing? Also, I stopped to grab some food and after I started it up the truck started fine but the mini show 11.8 at first then it kicked up to 12.5 and slowly rose to 13.8. Seems kind of wacky, has anyone else experienced this? Could it be a coincidence that my batteries and/or alternator are going out at the same time I installed the mini?
What should the alternator be putting out?
jervi30 is offline
post #2 of 5 Old 05-28-2013, 12:31 PM
floorboy's Avatar
Kwinki dink I think. Alternator voltage sounds good. Get the batts tested.
Originally Posted by bjs505 View Post
Of course I'm handy under the hood, I currently own a cummins.
2010 F350 CCLB Cabelas Edition
No Limit cai, Mini Maxx, 5" turbo back Flo Pro, Sinister egr delete, Sinister coolant filter, Cat EC-1, PTP shift solenoid. 20x9 +18 XD Monsters
01' 7.3 CCLB, 6637,wicked wheel G2, HPX, PHP Hydra, MBRP 4" Turbo back, Bellowed uppipes, Stancor gpr, 6.0 cooler, Fpr, Glow shift exhaust, pyro, trans, 203*/billet housing/ Cat EC-1, '07headlights/05' grill, Oh8' gate.
78' F350 "dumpy" old school
floorboy is offline
post #3 of 5 Old 05-29-2013, 12:33 PM
flashover1969's Avatar
Send a message via Yahoo to flashover1969
It's that time of year where it's starting to get hot and for some reason batteries love to die. I just had to replace both batteries. My truck was doing some of the same things as yours and it was the batteries. As for that purple wire it does have power. I hooked up my minima xx per the instructions and it works great.
flashover1969 is offline
post #4 of 5 Old 05-29-2013, 04:15 PM
WoodBoy's Avatar
Its always cold weather that I have my problems
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #5 of 5 Old 05-29-2013, 04:39 PM
Yeah batteries don't last very long in the Az desert heat where sometimes it feels like your living on the surface of the sun. Winters are mild and I've never had one die due to extreme cold. I'm sure some of our mountain residents have that problem though.
