ARP head stud info - Ford Powerstroke Diesel Forum
post #1 of 8 Old 05-27-2013, 06:54 PM Thread Starter
ARP head stud info
i just install ARP head stud and gasket on my 6.4,torque them to 275 like instruction said,i notice when i was torquing the nuts that the nut kind of back off or the stud itself is twisting when you release pressure from torque wrench,not by very much,but all of them did it,just wondering if its normal or if anybody run into the same thing
Girouard Racing is offline
post #2 of 8 Old 05-27-2013, 06:59 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
275 FT/LBS?? Really? WOW and I thought that 210 was a lot.
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #3 of 8 Old 05-27-2013, 07:03 PM
ZMANN's Avatar
Quoted: 1347 Post(s)
http://arpdiesel.com/Instructions/250-4203.pdf
u had plenty of lube correct ?
We Miss you Ronnie
ZMANN is offline
post #4 of 8 Old 05-27-2013, 07:11 PM Thread Starter
Yes,i did use the lube that came whit it,on your link there asking for 325,pretty sure my instruction sheet said 275,will check tomorrow
post #5 of 8 Old 05-27-2013, 08:16 PM
srjd's Avatar
Quoted: 2 Post(s)
I had mine done at 325
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #6 of 8 Old 05-28-2013, 06:58 AM
3brorce's Avatar
Pretty sure mine are torqued 10 over spec. They were once torqued studs.
Anarchy Diesel Tuning
3brorce is offline
post #7 of 8 Old 05-28-2013, 07:05 AM
WoodBoy's Avatar
Different lubes require different torques. Go by what comes in the package, those instructions may be older
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #8 of 8 Old 05-28-2013, 02:30 PM Thread Starter
Thank's for the info,i did use the lube that came whit it,also had added 10 lbs,e mailed ARP,according to them,its because of the long stud,
