I am planning on helping build a 6.4 and need advice - Ford Powerstroke Diesel Forum
post #1 of 8 Old 05-27-2013, 03:42 PM Thread Starter
I do not own te vehicle, I'm te mechanic chosen to do the upgrades, and I kind of have to do the research and decide for the kid.
It is a 2008 f250 6.4 4x4
It has - super chips programmer
Mbrp exhaust turbo back (no DPF)
4" lift
Updated up pipes
K & N cold air intake
He has a hi psi side batmowheel for me to install and I suggested getting the other one if I am going to go that far into it... Then he started asking dependability questions.... And here is what I have come up with
SINISTER DIESEL
- egr valve/cooler delete with intake elbow
- arp stud kit ( no gaskets ) just replace one by one
- coolant filter system
SUMMIT RACING
- 0-1,600 egt gauge
- 0-60 psi boost gauge
- 2 gauge A pillar pod
Anything I am missing and where I can locate the parts would be appreciated
THANK YOU
mattcampbell is offline
post #2 of 8 Old 05-27-2013, 05:03 PM
WoodBoy's Avatar
How many miles on the truck? I would go ahead and replace the gaskets when doing the studs if he plans on keeping the truck, go ahead and do it right the first time. Im not sure why he would do the HP Batmo before the LP Batmo? Although I have seen some Batmo failures lately
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #3 of 8 Old 05-27-2013, 05:17 PM
Big_Smokey's Avatar
Quoted: 9 Post(s)
Tell him to do studs and gaskets together.....and lose the spuerchip. get a spartan or h&s....then S&B intake or AFE....
Dont know much about the batmo. my truck runs like a striped ape with a mini max 300tune.
Big_Smokey is online now
post #4 of 8 Old 05-27-2013, 05:56 PM Thread Starter
The truck has 110k on it.... I thought the same with the superchip... Never been impressed.... I am trying to be able to keep the bill as low as I can with getting the most work reliability out of what I do... How necessary do you think pulling the heads and the machine work costs are necessary?
Do you like my input thus far?
post #5 of 8 Old 05-27-2013, 06:36 PM
Matt if you are doing studs a 110K pull the heads and have them checked, you 'll likely find some head truing and valve seats need attention.
Also consider going with a Spartan or H&S. I use a Spartan just for the Ford specific gauge/monitor capability. You will need to monitor a lot more then boost and egt on the 6.4 to be safe.
2008 F350 6.4 4x4 DRW CC 4:10 King Ranch Job3
Max2006 is offline
post #6 of 8 Old 05-27-2013, 07:01 PM
05_PSD_Erik's Avatar
As the others have said, if the owner wants reliability, ditch the Superchips. His transmission and engine will thank him with a long healthy life. H&S, Spartan or SCT tuning is the way to go. Otherwise, sounds like you are on the right path.
2009 Subaru WRX Premium
Type RS BOV
CAI
Muffler Delete
Had to park it with some real diesel muscle....
05_PSD_Erik is offline
post #7 of 8 Old 05-27-2013, 07:52 PM
I'd recommend getting a real tuner as well. But if you don't, take a look at the Aeroforce Interceptor gauge. It can display the EGT and boost that you're after, as well as a bunch of other stuff. It plugs into the OBD port, hopefully it would play well with the tuner. I'm planning on getting one to compliment my Mini Maxx but I haven't gotten around to it yet. And if you went with the Aeroforce gauge you could go with a single pod and keep the handle on the A-pillar. Just a thought.
Also, I've heard that Batmowheels don't preform as well as the stock wheels. I don't know that for sure, but I remember seeing some data to back it up. Take that for what it's worth, I guess.
You're on the right track though. The coolant filter, EGR delete, and studs are all good things to do. You can get that stuff from any of the big vendors. Most people wait until the gaskets go before doing studs, so he might want to wait on that if he's trying to keep the cost down.
One thing on the Sinister coolant filter, I had issues with leaks at the small T fittings and on the valves at the filter until I replaced the single hose clamps with 2 hose clamps per connection.
B. Adams is offline
post #8 of 8 Old 05-28-2013, 04:37 AM
WoodBoy's Avatar
He needs to swap out the HP Batmo wheel for the LP batmowheel instead first thing if he only wants to do one and save $400. The batmowheel does have improvement (Power and EGTs) over the stock wheels, but as I have stated, I have seen a couple explode lately. Not sure if its from alot of surging, improper torqueing, out of balance, or what, but I have seen it.
With 110k on the truck, there is no way I would do studs one at a time. The heads need to be checked, im sure there are cracks in it also.
Swap the programmer w/ one of the three the others have mentioned, that will help him drastically, he can always do the LP Batmowheel on down the road, the turbos dont have to come off for that. Also, swap the K&N intake. He may also want to look at a CAC pipe to replace the stock one
WoodBoy is offline
