Mini maxx EGT reading - Ford Powerstroke Diesel Forum
post #1 of 8 Old 05-25-2013, 10:07 PM Thread Starter
Yeah it's a Turbo Diesel
mts678's Avatar
Quoted: 7 Post(s)
Feedback Score: 12 reviews
My egt reading is wacko. I had to have some work done by the dealer and had my tech guy replace the egt sensor on the passenger side behind the fender well. That didn't fix anything. The reading jumps all over the place. From
250-300 at idle, when driving and cruising it shoots from 350-900-650-780- ECT. Just all over the place with no type of normal range from light throttle into heavy throttle.
Can I drill and tap into the egr cooler block off plate on the driver side up pipe? After looking at the mini maxx I don't see where an egt pyro would plug in?
Idk what to do but it sucks not being able to rest egt's!
Sent from AutoGuide.com App
Marshall
2002 F250 7.3L CCSB 4WD
Tinted | Focal speakers & 12" Kicker | CTS Insight | CNC fuel line kit | PIS 200/80's | KC38R | Nathan P3 train horns & Onboard Air
mts678 is offline
post #2 of 8 Old 05-27-2013, 09:59 AM
travisH3's Avatar
Quoted: 2 Post(s)
Feedback Score: 13 reviews
It doesn't plug into the mini maxx. It plugs into the block on the OBDII cord where the hdmi plugs in from mini maxx I believe
T-rav
2010 F350 6.4-
s467 MPD single kit, H&S Jesse Byall tuning, No limit IC piping and intake,mishimoto intercooler, MPD billet CCV/oil filler, FASS with sump, SOTA A.W.O.L. polished wheels, toyo rt tires, RED Newton traction bars, oem projector retrofit and a bunch of LED lights LOL
Holderdown Performance #teamHDP
OUR FLEET: 2015 f450, 2014 Platinum F350, 2012 F450 6.7, 2010 F350 6.4, 2005 F350 6.0, 04 F450 6.0
travisH3 is offline
post #3 of 8 Old 05-27-2013, 09:16 PM
TD-5's Avatar
Quoted: 3 Post(s)
If you want to add a non oem pyrometer, you will need this kit from H&S with the PCH board. The EGR block off plate would not be a good location as it is a dead end. you need to mount the pyro in the exhaust gas stream.
Universal Pyrometer Kit for Black Maxx/Mini Maxx (Includes Thermocouple and PCH) - Replacement Parts - Accessories / Replacement Parts
TD-5 is offline
post #4 of 8 Old 05-27-2013, 09:39 PM Thread Starter
mts678's Avatar
Quoted: 7 Post(s)
Thanks for the input y'all. I'll probably buy the h&s kit, although I'd rather utilize the factory pyro but not sure how to fix that? Doesn't it get it's reading from the egt probe on the passenger side up pipe area?
Marshall
mts678 is offline
post #5 of 8 Old 05-28-2013, 10:22 AM
TD-5's Avatar
Quoted: 3 Post(s)
Yes the factory pyro the H&S tuner is reading from the ECM is the one in the RH up pipe known as EGRT#1. Your symptoms sound like a bad wiring conection. I would double check to make sure they did actually change the pyro probe in that pipe. Then look closely at the plug & wiring the probe is conected to. Make sure the wiring hasn't rubbed through or burned & isn't grounding. The intermittent jumpy readings sound like a bad conection in the plug.
TD-5 is offline
post #6 of 8 Old 05-28-2013, 04:34 PM Thread Starter
mts678's Avatar
Quoted: 7 Post(s)
Thanks man, I'll investigate more closely and see what I can find. I'll take a video of my mini maxx too and post it up to make sure I'm not wrong- could be normal behavior but I don't think it is
Marshall
mts678 is offline
post #7 of 8 Old 05-29-2013, 02:13 PM
flashover1969's Avatar
Send a message via Yahoo to flashover1969
Sounds like a wiring/connector issue. I would check that out to see what's going on. Could be as simple as a little bit of corrosion at the connector.
flashover1969 is offline
post #8 of 8 Old 05-29-2013, 02:30 PM
unplug the pryo probe from the truck and see if the reading changes. i believe if the mini maxx is not getting a signal from the truck it reads 92.
also go thru the menu on the mini maxx and make sure it is set on pyro 1. if it is set on H&S pyros or pyro 2 it wont read properly
SOOTIE is offline
