Mini Maxx, S&B with 4" flo pro black smoke question - Ford Powerstroke Diesel Forum
post #1 of 9 Old 05-21-2013, 09:32 AM Thread Starter
I just deleted and got everything installed. I have been running stock on my 2008 so I am used to not seeing much or any smoke.
I expected there to be some after deleting but it seems like I am seeing more than I would expect. I am wondering what other people have experienced. If I put it on the performance tune and put it about 3/4's to the floor I can smoke out a city block, is that normal? I have my defuel set to the default of 2.
Even using the stock tune I get a lot of smoke when my foot get's heavy.
Apologies in advance if this is a dumb question but I'm a noob with this set up.
Let me know what you guys are experiencing. Thanks!
jervi30 is offline
post #2 of 9 Old 05-21-2013, 03:05 PM
Are you talking about the low boost fuel setting? It can be set from 0 to 5. The lower the number, the less smoke. I have mine set at 1 and it'll smoke only if I pound on it.
Try turning it down to 1 or 0 and see what happens.
B. Adams is offline
The Following User Says Thank You to B. Adams For This Useful Post:
raceit17 (04-08-2015)
post #3 of 9 Old 05-21-2013, 03:28 PM
Big_Smokey's Avatar
Quoted: 9 Post(s)
Make sure you have downloaded the new firmware and other updates to your mini. The older tunes are more smokey. I have my defuel at 5 and i dont smoke unless i hammer it and then it cleans up pretty quickly.
Big_Smokey is offline
post #4 of 9 Old 05-22-2013, 07:50 AM Thread Starter
Thanks for the info, I'm making the change now. When I went into the menu to change the low boos fuel settings it was on 3, I'm not sure if that is the default I thought 2 was the default, anyways I moved it to a 1 hopefully that will help.
I have the latest firmware 6.4.49.
Thanks again
jervi30 is offline
post #5 of 9 Old 05-22-2013, 11:11 AM
travisH3's Avatar
Quoted: 2 Post(s)
Feedback Score: 13 reviews
Thanks again
Yes default is 3. 3 is pretty smokey so I can't imagine how smokey 5 is. You should like 0 or 1.
T-rav
2010 F350 6.4-
s467 MPD single kit, H&S Jesse Byall tuning, No limit IC piping and intake,mishimoto intercooler, MPD billet CCV/oil filler, FASS with sump, SOTA A.W.O.L. polished wheels, toyo rt tires, RED Newton traction bars, oem projector retrofit and a bunch of LED lights LOL
Holderdown Performance #teamHDP
OUR FLEET: 2015 f450, 2014 Platinum F350, 2012 F450 6.7, 2010 F350 6.4, 2005 F350 6.0, 04 F450 6.0
travisH3 is offline
post #6 of 9 Old 05-24-2013, 06:05 PM
I havent played around with this setting yet but what does it do exactly other than control smoke.
X2guy is offline
post #7 of 9 Old 05-25-2013, 03:32 PM
Warheads on Foreheads
superdutydixie's Avatar
Controls how much fuel is used during low boost conditions
09 F-250 Superduty CCSB
SOLD
superdutydixie is offline
post #8 of 9 Old 05-27-2013, 08:47 PM Thread Starter
Thanks for the info. I guess I needed to re-read the manual. I downloaded the tune again and changed the low boost setting to 1, that made a big difference in the amount of smoke that it puts out. What are the down falls to having this set lower? Is it possible to run it too lean?
jervi30 is offline
post #9 of 9 Old 05-28-2013, 04:43 AM
WoodBoy's Avatar
No that isnt possible to run it too lean. There really isnt no downfalls to having it set that low. There is an advantage to it though that if you happen to stomp it, it doesnt overfuel your turbos
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
