Tuner after EPC-Converter delete - Ford Powerstroke Diesel Forum
post #1 of 4 Old 05-21-2013, 04:12 AM Thread Starter
I have deleted the EPF- and the cat. I now need to know which tuner that will get around the exhaust temps and the EGR block, and the plate block off of the egr coolers.
Please guys I am new to the 6.4 but the issue still stands.
08 6.4.
Thanks.
I am also looking for the half door driver side preferably black or dark.
Thanks for any help.
Union Buster is offline
post #2 of 4 Old 05-21-2013, 10:22 AM
F250Marine's Avatar
Do you mean the dpf? If you have already taken it out DO NOT DRIVE you truck it will go into limp mode. As for the tuners you can run spartan, h&s with the off road tunes, sct, or the dpf-R. Why did you delete with out having tuner on hand?
2008 F-250 Ext. cab FX4, Spartan tuned 300 EL, S&B intake, 4''DP, 5" flo-pro straight exhaust w/ black 6" MBRP tip.
Coming soon 4.5" Rough Country Lift w/ 18" Ballistic Jesters wrapped in 35X12.5 Nitto Trails
F250Marine is offline
post #3 of 4 Old 05-22-2013, 04:50 AM Thread Starter
exhaust converter and epf delete
This truck is not being driven at this time.
I'm going to block the egr coolers also.
I just need some pointers as to what to do for inspections.
post #4 of 4 Old 05-22-2013, 09:23 AM
F250Marine's Avatar
Where do you live? I live in Colorado I only have to do an missions test every two years. I plan on just going back to stock for the test. That's what I would do also
