Getting a new trans!! :) - Ford Powerstroke Diesel Forum
post #1 of 7 Old 05-17-2013, 09:13 PM Thread Starter
Cool Getting a new trans!! :)
I will be investing in a new trans and converter soon and need some input about tunes. Truck is '10 F250 6.4, DPF/DOC delete, EGR delete, Mini Max with KEM tunes, SB intake, 4in lift on 35s. I stay on the 250 tune most of the time, and drop to the 210 tune when towing (just for piece of mind).
New trans will be the Suncoast built by them with Suncoast converter OR rebuilding mine with new Suncoast parts and Suncoast converter.
Question: Will the new trans/converter setup interfere with the current KEM tunes? Do I need new tunes specific to the new trans/converter setup? I just want the new stuff to work smoothly with what I've done already.
Thanks for the input
millman02 is offline
post #2 of 7 Old 05-18-2013, 06:23 AM
F250Marine's Avatar
I know Jeff with spartan is running the sun coast trans and an rcd high stall converter and has been very happy with that set up. If I was to do it, or better yet when do it, I would look into the spartan tcm controller for sun coast.
2008 F-250 Ext. cab FX4, Spartan tuned 300 EL, S&B intake, 4''DP, 5" flo-pro straight exhaust w/ black 6" MBRP tip.
Coming soon 4.5" Rough Country Lift w/ 18" Ballistic Jesters wrapped in 35X12.5 Nitto Trails
F250Marine is offline
post #3 of 7 Old 05-18-2013, 06:44 AM
WoodBoy's Avatar
I would definately look into a DPC, RCD, or Precision convertor instead
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #4 of 7 Old 05-18-2013, 06:52 PM Thread Starter
Yeah I'm open to any brand converter etc I'm sure they are all reliable! I'm curious about the tunes themselves. Suncoast said their product would not need any specific tunes and that the modifications are compatible with tuned or non tuned trucks. KEM said I need different tunes to work with the new hardware. :-/
2010 F250 6.4L 4x4, CC SWB, Lariat, Ignot Silver
H&S Mini Max, DPF/DOC/EGR delete, Flo Pro 4in,
KEM TUNED, SB intake, Rancho 4in lift on 35s
post #5 of 7 Old 05-20-2013, 07:35 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
I am pretty sure he is running a low (1600) stall RCD torque converter
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #6 of 7 Old 05-20-2013, 06:01 PM
strokin07's Avatar
Jeff is running the 1600 stall. I have the same trans setup as Jeff and love it.
2008 F-250 KR
7" ICON
7" PMF blocks
Bilstein 5160F/5100R
22x14 Fuel Octane
37" Toyo M/T
H&S Mini Maxx w/ Gearhead tuning!
5" Diamond Eye
4" Diamond Eye DP
ARP head studs
Custom Stock Intake
RCD converter, HD billet input, low/rev hub, suncoast clutches.
160k miles and counting...
strokin07 is offline
post #7 of 7 Old 05-20-2013, 06:02 PM
strokin07's Avatar
There shouldn't be a reason to get new tunes
2008 F-250 KR
7" ICON
7" PMF blocks
22x14 Fuel Octane
37" Toyo M/T
5" Diamond Eye
4" Diamond Eye DP
ARP head studs
Custom Stock Intake
