Ccv mod stinks! - Ford Powerstroke Diesel Forum
post #1 of 14 Old 05-11-2013, 07:29 PM Thread Starter
Ccv mod stinks!
I have a DIY ccv mod and just vented to atmosphere I was wondering if there was anything you could do to get rid of the smell coming out of it or do people just live with it? I have it venting just over the rear axel but I still get whiffs of it in the cab sometimes.
Sent from AutoGuide.com App
2008 F250 XLT 4X4
H&S Mini Maxx
S&B CAI
5" Turbo Back Diamond Eye Exhaust
Sinister EGR Delete
CCV Mod
Fabtech Dual Steering Stabilizer
6" Pro Comp Lift
37x13.5-20 Toyo Open Country MT
20" Dick Cepek DC-2 Rims
bag711 is offline
post #2 of 14 Old 05-11-2013, 08:05 PM
zdawg8394's Avatar
do you have a back glass window that you use? those can be bad about sucking on air from the exhaust and stuff behind the vehicle. my old h2 use to do it. I would try moving the location of the hose end for the ccv mod around a little, maybe it will catch a different path of air? other than that you pretty much have to live with is or get a closed system.
zdawg8394 is offline
post #3 of 14 Old 05-11-2013, 09:33 PM
h1gg1n5's Avatar
Yeah mine stinks as well but everytime a lil wiff blows into my back slider window all I think is imagine how bad it is going into your intake on a constant basis.
Mine is on a 12ft hose and vented down by the rear axle. It only blows up sometimes with the wind. I moved mine around and it cut down on the smell.
2008 F450 CCLB KING RANCH
H&S Mini Maxx w/ Gearhead Tunes | DPF & EGR Removed | Downpipe | CAC Pipe | CCV Mod | Injen CAI |Dieselsite Coolant Filter & Boots| Mishimoto Rad | BFC Headlights
h1gg1n5 is offline
post #4 of 14 Old 05-12-2013, 07:13 AM Thread Starter
Yea I used to have it vent right under the back doors but I moved it to the rear axle it did help with the smell but it would be nice to get rid of it completely
2008 F250 XLT 4X4
H&S Mini Maxx
S&B CAI
Sinister EGR Delete
CCV Mod
6" Pro Comp Lift
bag711 is offline
post #5 of 14 Old 05-12-2013, 07:21 AM
cbenn's Avatar
Quoted: 2 Post(s)
Add a catchcan type with a drain, that's what I did and then you just drain it when you need to, NO smells
Just purchased a new 2016 CC
SOLD
2008 F350 CC SRW, 4X4/LB
Spartan Tuned/Spartan TCM
1722 Elite Head Studs/ChromeMoly pushrods
Bullet Proof 1/2 oil cooler kit
4" Down Pipe/4" DPF/Cat Delete
Diamond Eye 5" DPF back/5" Areo Turbine Muffler
3" CAI/inter cooler
S&B-CAI
CCV mod w/catchcan
Big Wig Sway Bars
PMF Traction bars
Icon 2.5 front coil springs
Bilstein shocks/Top Gunz dual stabilizer w/Bilsteins
Airlift/remote airbags
Viper 5701 w/SmartStart
cbenn is offline
post #6 of 14 Old 05-12-2013, 07:29 AM
h1gg1n5's Avatar
Yeah that would be about the only was to completely eliminate the smell completely. I have read somewhere about someone dumping it into their exhaust too but I have no idea how well that would work.
h1gg1n5 is offline
post #7 of 14 Old 05-12-2013, 09:23 AM
zdawg8394's Avatar
has to be done with Venturi tubes. if there is not enough of an angle the exhaust pressure will blow into the hose, to much angle the exhaust will suck and cause a vacuum. way to sketchy for me, could really mess something up.
post #8 of 14 Old 05-12-2013, 01:55 PM
h1gg1n5's Avatar
Thanks for the info. It seemed like it would be too much work and now with what you say sounds equally sketchy as well. Not worth it....
h1gg1n5 is offline
post #9 of 14 Old 05-12-2013, 02:07 PM Thread Starter
I was thinking the same but after that explanation I definitely won't do it.
2008 F250 XLT 4X4
H&S Mini Maxx
S&B CAI
Sinister EGR Delete
CCV Mod
6" Pro Comp Lift
bag711 is offline
post #10 of 14 Old 05-12-2013, 02:58 PM
srjd's Avatar
Quoted: 2 Post(s)
It really depends on the oil I use mobil 1 5/40 and 0/40 and the 0/40 really stinks bad but it doesn't bother me at all
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
