Do the 6.7's make the same power as the 6.4 with bolt-ons? - Ford Powerstroke Diesel Forum
post #1 of 28 Old 05-11-2013, 03:14 PM Thread Starter
Wondering if the 6.7's have the same power potential as the 6.4's
'08 F250 Regular Cab 4x4 (sold)
MBRP dpf delete
MBRP intercooler pipe
S&B intake
IDP/ SCT tuned
Suncoast Trans (built by Quin Trans in Lompoc, CA)
Cal-Tracs
Eaton Tru-Trac
12.76 @ 105.50, 1.80 60ft (before trans or intercooler pipe)
lxcoupe is offline
post #2 of 28 Old 05-12-2013, 07:31 AM
WoodBoy's Avatar
As of right now, they arent making the same bolt on for bolt on, but you never know what could happen
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #3 of 28 Old 05-12-2013, 07:36 AM
08stroker250's Avatar
With a stock high pressure pump and stock turbo, no.
Jeff Dodd
2012 Ford F-250 Lariat CC/SB
Mods - Spartan tuned via laptop, 4" AFE stainless exhaust system, 2.5" PMF BMC leveling spacers, 3" PMF lift blocks, Fox Racing 2.0 shocks, Recon smoked mirror & cab lights
08stroker250 is offline
post #4 of 28 Old 05-12-2013, 07:39 AM
I laid down 630rwhp, from what I've seen you need a good bit of cash in anything else to get in that ball park
Trouble maker is offline
post #5 of 28 Old 05-12-2013, 03:52 PM Thread Starter
Ok with the basic intake, DPF/ cat delete pipe, and tune they aren't making nearly as much, or not quite as much ? I searched 6.7 powerstroke dragstrip on youtube and I didn't find any of them even getting into the 13s. The 6.4's are in the 13s and 12s with these parts it seems.
MBRP dpf delete
S&B intake
IDP/ SCT tuned
Cal-Tracs
Eaton Tru-Trac
lxcoupe is offline
post #6 of 28 Old 05-12-2013, 03:54 PM
dieseljosh07's Avatar
The 6.7 runs out of air too fast to equal the power that 6.4's can produce.
dieseljosh07 is offline
post #7 of 28 Old 05-12-2013, 04:10 PM Thread Starter
So the cylinder heads don't flow as well, or the cam is milder?
MBRP dpf delete
S&B intake
IDP/ SCT tuned
Cal-Tracs
Eaton Tru-Trac
lxcoupe is offline
post #8 of 28 Old 05-12-2013, 04:21 PM
You asked if they are as powerful. You got your answer, now who cares why.
post #9 of 28 Old 05-12-2013, 04:39 PM Thread Starter
wut u have done?
MBRP dpf delete
S&B intake
IDP/ SCT tuned
Cal-Tracs
Eaton Tru-Trac
lxcoupe is offline
post #10 of 28 Old 05-12-2013, 05:06 PM
Basic bolt ons
