Took her to the 1/4 mile for the first time! IDP tune, MBRP, S&B intake - Ford Powerstroke Diesel Forum
post #1 of 23 Old 05-10-2013, 03:42 PM Thread Starter
Ran a 12.76 @ 105.50 on stock tires, 1.80 60ft on a 4wd launch, foot braking to 1500 rpm and flooring it on the yellow.
Got A LOT of guys at the track puzzled at how the truck was so quick.
Mods are IDP Extreme X tune, GoGo trans solenoid, S&B intake, MBRP 4" dpf/ cat delete, Cal-Tracs.
'08 F250 Regular Cab 4x4 (sold)
MBRP dpf delete
MBRP intercooler pipe
S&B intake
IDP/ SCT tuned
Suncoast Trans (built by Quin Trans in Lompoc, CA)
Cal-Tracs
Eaton Tru-Trac
12.76 @ 105.50, 1.80 60ft (before trans or intercooler pipe)
lxcoupe is offline
post #2 of 23 Old 05-10-2013, 03:59 PM
Nice run, its always fun to see guys face once u make a pass in a 4wd PSD lol!!!
g4dadon is offline
post #3 of 23 Old 05-10-2013, 04:28 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
What's your truck weigh?
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #4 of 23 Old 05-10-2013, 04:40 PM
sprksonu's Avatar
damn that is a good run buddy!
WRECKED EM DAMN NEAR KILLED EM!
2005 f250 ccsb 4x4 Studded, 03 turbo w/billet wheel, AFE stage2, 5"diamond eye, BPD egr cooler & "NEW" external oil cooler, BPD 48v FICM, BPD water pump, BPD aluminum radiator, 6.4 banjo's, blue spring, HFCM e-z drain, riff raff boots, gearhead srl tune , PHP FICM tune, sct livewire 5015, updated stc, updated stand pipes & dummy plugs, updated oil feed & drain, Zerex ELC coolant, Pro Comp 6" lift, 325/70/17 Toyo open country at
sprksonu is offline
post #5 of 23 Old 05-10-2013, 05:05 PM Thread Starter
Weighs 7300 with me in it and 20 gallons of diesel in the tank.
MBRP dpf delete
S&B intake
IDP/ SCT tuned
Cal-Tracs
Eaton Tru-Trac
lxcoupe is offline
post #6 of 23 Old 05-10-2013, 05:06 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
There is no way it weighs that much. It is a regular cab long bed 4x4. Curb weight on those are under 6100 LBS.
l BRYAN l
COMPIGNTECH .COM
[A Few Odds-N-Ends]
Tuscany is offline
post #7 of 23 Old 05-10-2013, 05:12 PM Thread Starter
Then the local city scale where I had it weighed for registration must be 1000lbs off
MBRP dpf delete
S&B intake
IDP/ SCT tuned
Cal-Tracs
Eaton Tru-Trac
lxcoupe is offline
post #8 of 23 Old 05-10-2013, 05:37 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
That very well could be. Either way it was a great run. Good job.
l BRYAN l
COMPIGNTECH .COM
[A Few Odds-N-Ends]
Tuscany is offline
post #9 of 23 Old 05-12-2013, 08:35 AM
WoodBoy's Avatar
Wrong, Rudys truck stripped weighs in at 6400 lbs. His weight should be about right
OP, you could have gotten some better times if you got that 60ft down
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #10 of 23 Old 05-12-2013, 02:09 PM Thread Starter
Ok good because I pay more registration fees every year based on how heavy it is...
MBRP dpf delete
S&B intake
IDP/ SCT tuned
Cal-Tracs
Eaton Tru-Trac
lxcoupe is offline
