Key position during Installing Download....? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 05-09-2013, 04:43 AM Thread Starter
NVHunter83's Avatar
This is a dumb question however I don't want to screw anything up with my truck...
The instructions to download the tunes into the truck say to turn the key to the "run" position, before downloading. Would this be the same key position where I see the glow plug indicator light, light-up and then turn off without starting the truck?
What are all the key positions for the ignition? Off, Acc, run/on, start?
Wouldn't the key already need to be in this position (run/on) for the Mini Maxx to be on, if so, why or how would I turn it to the "run position then as the instructions state to do? I have the mini maxx hooked up to the keyed power wire (solid purple wire).
I'm not sure if I'm over thinking this but like I said, I don't want to fry my ECM or screw anything up.
Also, the tuner was built in October of last year, and needs to be updated. Should I update the tuner before I install it into the truck? Or install the tuner as is, and then update it? I've been using the mini as a set of gauges to see what the truck is doing stock for now.
(1200* EGTs during regen is stupid while just driving down the highway BY THE WAY!!!)...
Thanks for the advice in advance.
Mike
2008 Ford F-350
6.4L Power Stroke
Crew Cab Long Bed
Buck Stop Bumper w/
WARN 9500 lbs. Winch
H&S Mini Maxx w/ homemade mount
5" Flo-Pro DPB exhaust w/ muffler
Bilstein 5100s Shocks
AFe Stage II Magnum Force Intake
NVHunter83 is offline
post #2 of 2 Old 05-09-2013, 04:49 AM
floorboy's Avatar
You are correct on the key position. My tuner stays on all the time unless I shut it off
Originally Posted by bjs505 View Post
Of course I'm handy under the hood, I currently own a cummins.
2010 F350 CCLB Cabelas Edition
No Limit cai, Mini Maxx, 5" turbo back Flo Pro, Sinister egr delete, Sinister coolant filter, Cat EC-1, PTP shift solenoid. 20x9 +18 XD Monsters
01' 7.3 CCLB, 6637,wicked wheel G2, HPX, PHP Hydra, MBRP 4" Turbo back, Bellowed uppipes, Stancor gpr, 6.0 cooler, Fpr, Glow shift exhaust, pyro, trans, 203*/billet housing/ Cat EC-1, '07headlights/05' grill, Oh8' gate.
78' F350 "dumpy" old school
floorboy is offline
