PTP Solenoid question - Ford Powerstroke Diesel Forum
post #1 of 5 Old 05-08-2013, 04:54 PM Thread Starter
maddenjr's Avatar
Send a message via AIM to maddenjr
So whats the gains and has anyone been using the PTP Modified Direct Clutch Solenoid ? I have been noticing a slight chatter into reverse sometimes and im gonna do a trans service so im thinking i might order it. Plus does anyone know if its a big deal to install?
Spartan,Afe,Mbrp Delete with duals,Banks Intercooler,Custom CCV Mod,22.5 American Forces,Flo Pro egr delete,Lots of Strobes,Atomic Strobes,5%Tint and 20% Windshield Tint,B&W gooseneck,K3LA Train horns and some other goodies, Head studs and waste gate coming this spring
2001 F350 Flatbed/Car Hauler, Ext Cab,07 Front End w/Cowl Hood,SCT Tuned,MBRP Straight pipe
92 Mustang Lx Hatch X275 Drag Radial been low 7's
03 Cobra with a lil extra boost
maddenjr is offline
post #2 of 5 Old 05-10-2013, 10:54 AM Thread Starter
maddenjr's Avatar
No one knows anything about this?
maddenjr is offline
post #3 of 5 Old 05-10-2013, 11:21 AM
DoubleDpsd's Avatar
Shutter in reverse is a bad sign, almost death sentence. I wouldn't waste money on a solenoid. It's possible it's already too late. I believe shutter in reverse is related to direct clutch failure.
2003 centennial edition f250 4x4 ccsb auto w/blackwater long block w/arp's, 4" exhaust, airaid intake, ODawg's manifold, itp's reg return, sap modified solenoid, DC power 185amp alt, motorcraft 850cca, Warn Hubs, RS 55w 6k hid's, harley headlights, bpd 58v 6 phase, bpd water pump, dieselsite coolant filter, elc coolant, php gryphon, Xcal2 w/unlimited tow, new hfcm, glowshift fuel psi gauge, icon level kit, 20" kmc hoss, 305/55 terra grapplers TOTALED
DoubleDpsd is offline
post #4 of 5 Old 05-10-2013, 01:49 PM Thread Starter
maddenjr's Avatar
It has shuddered into reverse since the day the truck was brand new and i also had the rev and slam issue which it set shift solenoid codes and ford put a valve body under warrenty... Hasnt got any worst just the only thing is the truck chatters into lockup but only when towing... Empty its perfect!
maddenjr is offline
post #5 of 5 Old 05-10-2013, 02:07 PM
MyTractorsSexy's Avatar
Quoted: 7 Post(s)
the solenoid took 30 minutes from start to finish. draining fluid, removing pan, replacing solenoid, putting pan back on, ran it through every gear then did a burn out. very simple. also replaced both filters.
Mild build 07 F250-SOLD
2011 Black CC SB Lariat F250, 2015 Retrofit, MPD IC Piping, H&S Mini Maxx custom tuned, 5"Flo-pro Exhaust, Sininster Egr Delete, Recon Lighting, No Limit S2 Intake, Tinted, BDS 8" 4-Link Lift w/ Fox Shocks & Dual Steering Stabilizer, 4.10 Yukon's with electric lockers, 37/13.50/22 Toyo MT, 2-Piece Fuel Maverick 22x12 Wheels, PTM Grille Surround, T REX X-Metal Grille, LED heads and fogs, kenwood double din, 4 hertz 210W door speakers 2 JL TW3 10s kenwood amps.
MyTractorsSexy is offline
