WASTEGATE INFO!! - Ford Powerstroke Diesel Forum
post #1 of 5 Old 05-05-2013, 09:25 PM Thread Starter
DieselPowerFan's Avatar
WASTEGATE INFO!!
Hey guys, to those of you that are running a wastegate. Could you give the size, type, install location, and pro's and con's, oh and pics would help a bunch!
Thanks!
DieselPowerFan is offline
post #2 of 5 Old 05-06-2013, 07:53 PM
WoodBoy's Avatar
Most run Tial MVR or Precision. 40-44mm is enough. What are the mods to your truck? Pros are controlling backpressure if you have added fuel upgrades, cons are tuning the gate. Some put the gate at the end of the egr pipe but it is best to have it as close to the turbo as possible for reaction time purposes
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #3 of 5 Old 05-07-2013, 07:02 PM Thread Starter
Great! thanks for the Response.
Someone suggested using a Tial 38mm. Any thoughts on this guys? or just stick with a 40-44mm??
Also when I said pros and cons, I meant referring to specific brands in use, like brand A vs brand B.
I'm currently collecting all the parts necessary to build a strong package. H&S mini (off road), 5" turbo back Flo Pro (4" DP), banks intake, Flo Pro intercooler pipe, Sinister EGR delete (will be doing full delete), ccv mod, FASS sys, Dieselite boots, Sinister coolant filter sys, larger sway bars, traction bars, also has a 6" lift 37's on 20".
I was/am just curious as to what size of waste-gate was recommended for the 6.4 with these types of mods, and where the best ideal location is for it. I've got all these parts ordered and some installed already etc. Just trying to build a solid package!
Thanks again for the response!
post #4 of 5 Old 05-08-2013, 07:11 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
With the mods you have listed i would not bother with a wastegate. WHen you add more fuel them add a wastegate.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #5 of 5 Old 05-09-2013, 07:29 PM
WoodBoy's Avatar
I also wouldnt recommend a wastegate at this time
WoodBoy is offline
