Mbrp v Diamond Eye - Ford Powerstroke Diesel Forum
post #1 of 12 Old 05-02-2013, 05:45 PM Thread Starter
Mbrp v Diamond Eye
What do you guys think about either or looking for pros and cons of both. Definitely going to get one of them just not to sure which, im gonna go with the 4" single turbo back thanks in advance for the input guys!
Mmace111 is offline
post #2 of 12 Old 05-02-2013, 07:42 PM
WoodBoy's Avatar
Ive always like the MBRP and Flo Pro kits. Not a big fan of Diamond Eye
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #3 of 12 Old 05-06-2013, 04:32 AM
Their isn't much difference other than the price from what I have seen.
schnet1 is offline
post #4 of 12 Old 05-06-2013, 06:11 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
I went with the Diamond Eye. The kit is very easy to install. Pipe seems to be heavy walled enought that I doubt Ill ever replace it. The sound is great. Id go with the same set up agin if I had to.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #5 of 12 Old 05-06-2013, 06:54 AM
Another vote here for MBRP!! Great Product, Great Fit
2009 F-250 FX4 CC/SB
H&S Mini Maxx
S&B intake
Sinister Diesel Coolant Filter
MBRP 5" Exhaust, 6" Tip
Toyo AT2 285/75/18
Line x'd Bed
HID Retro w/ FXR 3.0's
Mods to come;
Egr Delete/CAC Pipe/Turbo Downpipe
verifine is offline
post #6 of 12 Old 05-06-2013, 07:03 AM
Real Men of Genius
Super Diesel's Avatar
Quoted: 10 Post(s)
Feedback Score: 9 reviews
This is just my opinion, but the MBRP exhaust is a better fit. I've ran 3 MBRP exhaust systems on my past trucks - and I've seen/helped install several other exhaust systems as well. The Diamond Eye kits do not fit as well as the MBRP ones from every install I've seen and I've heard this from several members of my truck club that have the Diamond Eye exhaust as well. However, both perform and function the same. I'm partial to the MBRP exhaust tone, however the Diamond Eye kits aren't much different.
Chris | 2005 F-250 RCSB | "Ranger - Turbo Diesel V8"
CED Compounds - Conventionals - Supporting Mods
Super Diesel is offline
post #7 of 12 Old 05-06-2013, 07:23 AM
Fit and install on my diamond eye went smooth with no problems and as long as its a straight pipe the sound wont change at all compared to an mbrp
lazlow is offline
post #8 of 12 Old 05-06-2013, 07:30 AM
Korx's Avatar
I like my diamond eye, was cheaper than MBRP off of amazon. I went with a straight pipe I figured pipe was pipe at the time. I think it sounds great, and install was a breeze.
2004 6.0L F-250 XLT - ECSB
CTS SCT
Deleted
Studded
5" Exhaust
175cc Injectors
1995 7.3L 5-Speed F-350 XL Dump
Stock
Korx is offline
post #9 of 12 Old 05-06-2013, 09:49 AM
kosmo04's Avatar
I went with diamond eye, however I had to have part of it expanded because it didn't fit properly, but my case is the only one i've heard like it.
08 F250, CC SRW
H&S Mini Max, S&B Intake, 5" Diamond Eye DP back, MBRP Coldside Intercooler Pipe
37x12.5x20 Nitto Trail Grappler M/T, 4.5" Rough Country Lift w add-a-leafs
kosmo04 is offline
post #10 of 12 Old 05-06-2013, 11:33 AM
I have used both and I have to say for the money....Diamond Eye is a great option. I had no problems with the fit and install. However, every truck is different and every batch of exhausts is diffferent. Save the cash and spend it somewhere else.
2010 Ford F-250 Super Duty, Lariet 4x4, Crew Cab Short Bed, loaded with every option...and more
turbo kidd is offline
