MPG downer - Ford Powerstroke Diesel Forum
post #1 of 11 Old 04-29-2013, 01:02 PM Thread Starter
MPG downer
I just installed a Minimax, EGR delete and a dpf delete pipe. I was under the impression i would get better mpg's but im only getting 10 mpg. Is there something i did wrong? Shouldnt i get better mpg?
furdcrew is offline
post #2 of 11 Old 04-29-2013, 02:39 PM
srjd's Avatar
Quoted: 2 Post(s)
I don't have a exact answer for you but that's way off I'm getting 17mpg with 37s on the highway. Also is this hand calculated? If not then hand calculate cause the dash is always off
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #3 of 11 Old 04-29-2013, 06:31 PM Thread Starter
What tune are you running?
furdcrew is offline
post #4 of 11 Old 04-29-2013, 06:39 PM
srjd's Avatar
Quoted: 2 Post(s)
H&s hd tunes mostly the street tune which is 225
srjd is offline
post #5 of 11 Old 04-29-2013, 08:11 PM
3brorce's Avatar
When I deleted egr my mileage actually went down also and didn't change at all once dpf left either. All trucks are diff
Anarchy Diesel Tuning
3brorce is offline
post #6 of 11 Old 05-01-2013, 04:40 PM
I've noticed that my mpgs have gotten better over time since tuning. Originally tuned in spring of '11, I got just about 11 mpg right after tuning. Since then, the mpgs have been steadily climbing to their most recent point (calculated after filling up the tank this morning) of 14.9 for city driving.
ZCLynch is offline
post #7 of 11 Old 05-01-2013, 05:16 PM
srjd's Avatar
Quoted: 2 Post(s)
Calculating milage in the city is a waste of time you never drive the same traffic is different way to many variables
srjd is offline
post #8 of 11 Old 05-02-2013, 02:10 PM
44magnum's Avatar
Quoted: 2 Post(s)
When I first deleted I got about 12.5 now I get about 14.5 mpg. It seemed to get better the longer i stuck with one tune. The latest tune from h&s helped. although my boost Is much higher than before. That's with a 60/40 mix and I drive gently but not like an old lady. I also have my LBF at 5. With the 250 tune.
[FONT=Verdana][I][B][SIZE=2]2008 (Job 1) F250 King ranch 4x4, snow plow prep package with 2.5 level. Black Maxx, B&W Diehard platinums. Dieselsite coolant and transmission filters, NCU Motorsports/amsoil oil bypass kit. Turbo blankets, 5.5" blocks & PMF "floating" traction bars
44magnum is offline
post #9 of 11 Old 05-02-2013, 06:40 PM
Big_Smokey's Avatar
Quoted: 10 Post(s)
Stock tires and suspension i was getting 18 average hwy hand calculated.....then now im seeing around 14 or so after the lift and wheels, tires.
mostly ran on the hot tune, performance tune.
You didnt say if you were lifted, or wheels tires. those two things individually drastically change the MPGs.
Big_Smokey is offline
post #10 of 11 Old 05-03-2013, 04:23 PM
Dustin f2504x4's Avatar
My F250 with the H&S gets 15 to 17mpg and it has 35 inch tires. I have the H&S set on the hd 300 tune lbf set on 3. It gets 12 on a bad day.
Dustin f2504x4 is offline
