Transmission Fluid - Ford Powerstroke Diesel Forum
post #1 of 19 Old 04-28-2013, 02:47 PM Thread Starter
Powerstrokin_08's Avatar
Quoted: 5 Post(s)
Transmission Fluid
About that time to change out the fluid and filter. Any particular fluid yall are running? I ran Amsoil Syn. in my Dodge but dont know a lot about the Ford transmissions.
Thanks in advance.
2013 King Ranch F-250 CCSB 6.7L 4x4
Carli 2.5" Leveling Kit
4" Rear blocks
Bilstein 5100's
AMP Research steps
Plain and Simple Custom Headlights
35" Toyo MT's on King Ranch rims
Fab Four Black Steel bumpers front and back
5" Flo Pro
No Limit EGR/Cooler Delete
Edge CTS2
PPEI EzLynk
*SOLD*2008 F-350 CCSB 6.4L 4x4
4" DP back
H&S Mini Max
Sinister EGR/Cooler Delete w/Intake Elbow
Carli 2.5 Pin Top Suspension
S&B CAI
NC Hornet CCV mod
20's&35's
Powerstrokin_08 is offline
post #2 of 19 Old 04-28-2013, 03:26 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
Mercon SP or LV only. I would stay with SP if possible.
dhanna6powerstroke is offline
post #3 of 19 Old 04-28-2013, 04:18 PM
WoodBoy's Avatar
As stated Mecron SP.
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #4 of 19 Old 04-28-2013, 04:27 PM
Thanks in advance.
ABSOLUTLY!!! Amsoil, it's the best there is, handles heat and protects better than anything else you can buy IMHO.
2000 f-350 ccsb 4x4 srw, banks ram air intake, amsoil lube front to back!
jerry j is offline
post #5 of 19 Old 04-28-2013, 04:51 PM
Mod Newbie
Quoted: 20 Post(s)
Not in a 5r110 Torq Shift
post #6 of 19 Old 04-28-2013, 04:56 PM
tkobes43's Avatar
Quoted: 2 Post(s)
Garage
^^^ Agree, ONLY use Mercon products! Should say the exact kind on the trans dip stick!
Tom
5" MBRP Straight Exhaust w/ 6" tip, SCT Monitored, Limo Tints, 20" LED Lightbar, 8k HIDS, & Some other goodies
Other Rides
1978 Trans Am Y88 403 84k original miles
1996 Ford F350 PSD Mason Dump 134k Original Miles!
Gone But Not Forgotten... (Lilah) 2008 Ford F250 Lariat CrewCab
Proud To Be An American!
tkobes43 is offline
post #7 of 19 Old 04-28-2013, 05:01 PM
bubmiller's Avatar
If you use Amsoil, be sure to use the Low Viscosity. Their regular atf is not Mercon SP compatible.
06 F250 CCLB
Bulletproof FICM
Sinister EGR Delete
Pypes Exhaust
ARP studs
SCT X3 w/Pro Racer
bubmiller is offline
post #8 of 19 Old 04-28-2013, 05:02 PM
ZMANN's Avatar
Quoted: 1790 Post(s)
Mercon SP/LV
ot Valvoline Max life Dex Merc
is stated on the Bottle to be OK for Merc SP/LV
mater of fact Valvoline told Me they sell in bulk to a lot of ford dealers because it is also compatible with other types and keeps the amount of fluids they need to stock lower ( think Ford dealer with a used vehicle lot or multi Brand lot
and the service Dept
Overview
MaxLife DEX/MERC ATF contains a blend of superior base oils and a unique additive package to help extend the life of transmissions with over 75,000 miles. It is formulated to maximize transmission performance, reduce transmission wear, and improve and maintain smooth shifting longer than conventional fluids. MaxLife DEX/MERC ATF is compatible with new and rebuilt transmissions and will not void new car warranties.
Recommended for use where DEXRON, DEXRON II, III and VI, Toyota T-IV and WS, MERCON®, MERCON® SP and LV, Allison TES 389, Nissan Matic-D, Matic-J and Matic-K, Honda Z-1 (except CVT), Mercedes NAG-1, Mitsubishi Diamond SP-II and SP-III and many others are required.
We Miss you Ronnie
ZMANN is online now
post #9 of 19 Old 04-28-2013, 05:07 PM
ZMANN's Avatar
Oh and the Amsoil is 11.50 a qt why piss that extra money away ?
We Miss you Ronnie
ZMANN is online now
post #10 of 19 Old 04-28-2013, 06:09 PM
44magnum's Avatar
Quoted: 2 Post(s)
Well looks like Motorcraft sp/lv is $8.99 a quart while Amsoil is either $8.90 or $11.50 depending if your a preferred customer or not. You can also buy a "6 month trial preferred membership" for $10.
Has anyone had a bad experience using Amsoil low viscosity? I havnt found where it "meets or exceeds factory SP/LV specifications", or if its simply "compatible with".
Advance Auto Parts: Search Results for motorcraft mercon
[FONT=Verdana][I][B][SIZE=2]2008 (Job 1) F250 King ranch 4x4, snow plow prep package with 2.5 level. Black Maxx, B&W Diehard platinums. Dieselsite coolant and transmission filters, NCU Motorsports/amsoil oil bypass kit. Turbo blankets, 5.5" blocks & PMF "floating" traction bars
44magnum is offline
