Noise under throttle - Ford Powerstroke Diesel Forum
post #1 of 3 Old 04-20-2013, 05:53 PM Thread Starter
At half throttle I hear an intermittent noise that sounds like you are blowing into a reed, air filter is not dirty and I clean the pre filter regularly, this is not a constant noise but I would appreciate some possible causes for this.
Brickstone is offline
post #2 of 3 Old 04-20-2013, 06:18 PM
KCCO!!
kells17's Avatar
I have a gap in my exhaust pipe about mid way through, u-bolt is loose, been to lazy to tighten. I can hear "blowing" depending on my throttle response. Does it sound like its coming from the intake?
2004 F-250 Lariat CCSB
Studded, Deleted, Cold Air, Fog Light Mod,
IPR HF Coolant Filter, High Idle, Atlas 40 FICM,
CCV, Edge Insight CTS, ZooDad, BPD Oil Cooler,
4" Banks Monster Exhaust, Fumotos, 05 Harley Headlights,
Blue Spring, Kill Switch, 03 Turbo and 6.4 Banjo Bolts
VA Strokers
757 Diesel
kells17 is offline
post #3 of 3 Old 04-22-2013, 06:25 PM
Sounds like you are hearing what is called turbo flutter. It's normal and a lot louder with a cai.
Bellyboat is offline
