Towing heavy with Spartan? - Ford Powerstroke Diesel Forum
post #1 of 13 Old 04-14-2013, 04:25 AM Thread Starter
Vet4jdc's Avatar
I have been successfully towing a 6000 lb travel trailer with a Spartan tuned F250 SDCC using the 210 tune for the past 2 years. We just upgraded to a 11,000 lb fifth wheel. Can I still tow that weight on the 210 tune safely or should I be going back closer to stock?
Thanks in advance for any input!
2010 F250 SD 4x4 / DPF Deleted / 4" AFE Straight Pipe / Spartan Tuned / S&B CAI
Vet4jdc is offline
post #2 of 13 Old 04-14-2013, 06:37 AM
tkobes43's Avatar
Quoted: 2 Post(s)
Garage
I was always told to tow in stock mode UNLESS you have a specific tow tune, Since youve moved up to towing 11,000 pounds i would lower the tune much closer back to stock...
Thats just me
Tom
5" MBRP Straight Exhaust w/ 6" tip, SCT Monitored, Limo Tints, 20" LED Lightbar, 8k HIDS, & Some other goodies
Other Rides
1978 Trans Am Y88 403 84k original miles
1996 Ford F350 PSD Mason Dump 134k Original Miles!
Gone But Not Forgotten... (Lilah) 2008 Ford F250 Lariat CrewCab
Proud To Be An American!
tkobes43 is offline
post #3 of 13 Old 04-14-2013, 06:47 AM
sprksonu's Avatar
You are crazy and lucky at the same time WOW.
WRECKED EM DAMN NEAR KILLED EM!
2005 f250 ccsb 4x4 Studded, 03 turbo w/billet wheel, AFE stage2, 5"diamond eye, BPD egr cooler & "NEW" external oil cooler, BPD 48v FICM, BPD water pump, BPD aluminum radiator, 6.4 banjo's, blue spring, HFCM e-z drain, riff raff boots, gearhead srl tune , PHP FICM tune, sct livewire 5015, updated stc, updated stand pipes & dummy plugs, updated oil feed & drain, Zerex ELC coolant, Pro Comp 6" lift, 325/70/17 Toyo open country at
sprksonu is offline
post #4 of 13 Old 04-14-2013, 08:01 AM
cbenn's Avatar
Quoted: 3 Post(s)
Thumbs up Tow tune
I have a f350 and tow around 15,000 5th wheel and I use the Spartan 210 hp/ negr never an issue, living up here in Washington state there is always a mountain pass to climb to get to the east side of the state and never have an issue with the 210 everything stays within specs, always use the 210. an enjoy the ride/pull. Use the 210 you will be happy with the performance.
2017 F350 Lariat Dually
Airlift air bags W/ Wireless remote.
2.5 Icon coil springs
PMF adjustable track-bar
PMF dual steering stabilizer
cbenn is offline
post #5 of 13 Old 04-15-2013, 10:48 AM
08stroker250's Avatar
I'm curious....why?
Jeff Dodd
2012 Ford F-250 Lariat CC/SB
Mods - Spartan tuned via laptop, 4" AFE stainless exhaust system, 2.5" PMF BMC leveling spacers, 3" PMF lift blocks, Fox Racing 2.0 shocks, Recon smoked mirror & cab lights
08stroker250 is offline
post #6 of 13 Old 04-15-2013, 11:34 AM Thread Starter
Vet4jdc's Avatar
Originally Posted by 08stroker250 View Post
I'm curious....why?
Me too!
I always pulled 6000 lbs with low EGT's!
Vet4jdc is offline
post #7 of 13 Old 04-15-2013, 12:43 PM
countryraised's Avatar
you can tow in any tune you want as long as you can control your right foot... which can be an issue for a lot of us. As long as your temps stay down and your not puching from a stop and over stressing the driveline you'll be ok.
Vince
John Deere product developement
FOR SALE '99F350 2008 F350 mini maxx'd
countryraised is offline
post #8 of 13 Old 04-17-2013, 06:00 AM
I tow a 12,000 pound toy hauler on the 210 tow tune for the last 10k miles, so far works killer, no issues.
jdogg is offline
post #9 of 13 Old 04-21-2013, 08:40 AM
Quoted: 11 Post(s)
What boost pressures are you guys seeing towing? I towed about 6000lbs in a covered trailer last weekend. On a smooth grade on highway I was at around 15 lbs and any sorts of hill I was at 33-40LBS of boost. A large amount of the 3 hour drive i was low 20's. Wondering if this is pushing too hard or if I'm being paranoid. EGTs were 800-1000, trans temp was happy and I was enjoying going 80 with that trailer.
nater6.4 is offline
post #10 of 13 Old 04-21-2013, 03:40 PM
wilsonw2's Avatar
Quoted: 18 Post(s)
What were ur tranny temps? I typically see 180-200
Sent from AutoGuide.com App
*NEW:
2016 F250 CCSB KR FX4
NL Fab:
---Stage 1 Intake
---EGR shmock off plates
---Flo Pro Exhaust (5" to 6" tip)
---SCT with GH tunes
---Waiting for first Fuel Filter change to install:
---------CCV Mod
---------CTS2 monitor with EGT Probe
Just passed 1,111.1 miles and LOVING IT!
**SOLD:
2010 F250 CC FX4
H&S
AFE Intake
and some other goodies...
wilsonw2 is offline
