tuner question - Ford Powerstroke Diesel Forum
post #1 of 2 Old 04-12-2013, 11:16 AM Thread Starter
tuner question
I just ordered a mini max and i was wondering if i would have to get an aftermarket cold air intake or can i stick with the stock one? Also what would be the best setting on the minimax to tow a 10000 lb travel trailor safely? Thanks in advance!!!!!
furdcrew is offline
post #2 of 2 Old 04-12-2013, 12:43 PM
superduty6.4's Avatar
It isn't totally necessary to get a cold air intake. If you run it hard all the time on a big tune then you will be constantly sucking in the filter minder but if you drive sensibly you should be fine. I've been running an afe drop in filter for quite some time now with no issues. For the towing question, it's always recommended to tow in the lowest horsepower setting of whichever tune you are in. I run the hd300 tunes in the no power setting usually for towing and it is about a 50 hp boost.
08 F350 JOB 1
H&S MINI MAXX HD300 W/S1M
SINISTER EGR/COOLER DELETE
6000K BEAMERS HID HEAD & FOGLIGHTS
KMC XD WHEELS W/NITTO TRAIL GRAPPLERS
2.5" LEVELING KIT
DIESELSITE COOLANT FILTER
ROTELLA EC-1 RATED COOLANT
5" DP BACK FLO-PRO EXHAUST
FLO-PRO CAC PIPE & INTAKE ELBOW
CCV MOD
AIR LIFT 5000LB AIR BAGS W/ONBOARD COMPRESSOR
AFE CAI
PMF TRACTION BARS
superduty6.4 is offline
