Keep'n it simple- 6.4 mod help + - Ford Powerstroke Diesel Forum
post #1 of 10 Old 04-11-2013, 10:17 AM Thread Starter
Tunaahelper's Avatar
New to the forum. Owned several Dodge oil-burners in the past, but decided to go with a powerstroke this time.
Just picked up a CPO '08. Without digging through 15000 threads and old/outdated info, can someone gimme a few tips on what to do with the truck?
Don't want to void warranty- something that can be removed w/o trace when servicing.
Looking for better mileage.
Potential for more power.
Anything else I should be looking for such as cold-air etc?
Future projects-
DVD for nav head unit.
HID's
Lift
Adding USB ports
Thanks in advance and I look forward to contributing.
Jeff-
Thanks
Tunaahelper is offline
post #2 of 10 Old 04-11-2013, 01:02 PM
WoodBoy's Avatar
Future projects-
HID's
Lift
Adding USB ports
Jeff-
Thanks
Those in bold dont really go together. You can chance it and run a dpf delete tuner with a dpf delete. Wont see that much mpg gain, you will see a substantial amount of power and with good driving habits a more reliable/healthy motor. Once back for servicing or whatever if you want to swap it back you can, me personally if I was going to take it to get serviced every 5k miles there is no way I would return to stock everytime
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #3 of 10 Old 04-11-2013, 01:47 PM Thread Starter
Thanks Woodboy,
The more I look around, it seems that it's pretty much too involved. I'm not one to run to the dealer for oil changes etc, so it's major issues that I'd be taking it in for.
Guess I'll stick with a cold-air, lift etc. Till the warranty expires.
post #4 of 10 Old 04-11-2013, 02:08 PM
DirtyDiesel's Avatar
Quoted: 4 Post(s)
take into consideration the EGR on youre truck is slowly destroying youre engine. running the truck 50k miles with EGR might possibly take 100k+ off the life of the engine.
just my .02.
Brett
'08 Ford F-350 Powerstroke Lariet 4x4
SPARTAN Tuner, Flo-Pro 5" Exhaust 6" Tip, Deleted, S&B Intake, B&W Hitch, 2.5" Leveling kit, Custom Rear Traction Bars, 20x12 FUEL NUTZ, 33x12.5 Toyo MT's, PIONEER Screen, 3500W of ORION amps, Sundown SD3 10" subs, Blacked out Headlights, Retro LED bulbs, Recon Mirror Lights
DirtyDiesel is offline
post #5 of 10 Old 04-11-2013, 03:24 PM
WoodBoy's Avatar
I personally wouldnt do a CAI until I done the deletes
WoodBoy is offline
post #6 of 10 Old 04-11-2013, 07:05 PM
Quoted: 2 Post(s)
General 6.4 Modifications
start reading here.
Kris
2008 Ford F250 6.4L Crew Cab Short Bed King Ranch
3.5" ReadyLift Leveling Kit, 37x13.5x20 Toyo MT's on stock 20's, Dual Steering Stabilizer, Livewire w/ IDP, KEM, Gearhead, S&B, 5" Flo-Pro, Rudy's EGR Delete and Cold Side Pipe, CCV
p8ntballn2 is offline
post #7 of 10 Old 04-11-2013, 07:16 PM
for one any programmer u put on these trucks is going to leave a foot print in the pcm ecm tcm etc . the egr and dfp system on early 6,4s are known to be problematic . i would take it to the dealer to get a thorough look over and if all checks good get rid of the dpf and egr . the emission system on these trucks do more harm to the engine than there worth .
]2011 f250 king ranch cc/sb fx4 black and tan allot of inferior parts fell off so i put better ones on . 5inch exhaust axle dump s7b intake . blistien 5100s all the around . 20x12s on 305,55,20s .leveling kit with bags in the rear .5% tint all the way around
lhood6.7 is offline
post #8 of 10 Old 04-11-2013, 08:19 PM
srjd's Avatar
Quoted: 2 Post(s)
First call your dealership see how mod friendly they are and also with it being an 08 I'm assuming your warranty is almost up. I'm sure just about everyone on here will agree with me when I say I should have deleted way sooner and not been so concerned with warranty. You gotta do whatever makes you comfortable.
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #9 of 10 Old 04-11-2013, 08:25 PM
very true lol srjd
lhood6.7 is offline
post #10 of 10 Old 04-12-2013, 10:58 AM Thread Starter
Thanks for the link Kris. Just what I was looking for.
