spartan 210T bucking at 63 mph - Ford Powerstroke Diesel Forum
post #1 of 10 Old 04-10-2013, 01:12 PM Thread Starter
Hey there, for one my speedo is not corrected so this problem is more likely happening at about 66mph but I think that is irrelevent anyway as its probably rpm based.
at any rate when towing on incline with the spartan 210T tune my truck seems to start bucking at a very consistent speed of 63-64 mph. its like I am jerking my foot on and off the throttle, very quick jerks. at first I thought it was my foot bouncing due to a road bump or something but its not.
I have even done cruise control to take myself out of the equation, I can either stomp on it or let off for a second and it will stop, but sooner or later at that speed it will start. its never when I am passing this speed its just when I seem to be on an incline and maintaning steady, I have been avoiding this speed for a year now but it is getting old.
Any ideas, its only with the 210T, I have tried everything else from stock to 275 and it doesn't do it
Thanks
2015 F350 Platinum CCSB SRW
100% stock
SOLD: Black 08 F350 FX4
Spartan tuned
MBPR DP Back straight pipe
20' XD Hoss's
325/60 Duratracs
Leveled
chinaman is offline
post #2 of 10 Old 04-10-2013, 02:33 PM
WoodBoy's Avatar
Sounds like the frp surging very fast. A lot of trucks do it. When was the last time you updated
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #3 of 10 Old 04-10-2013, 02:41 PM
08stroker250's Avatar
A lot of people have pointed to the low pressure fuel pump causing it, and others have pointed to the high pressure pump causing it. It's hard to say because so many different people have different experiences with the "bucking" sensation, with different tuning.
Jeff Dodd
2012 Ford F-250 Lariat CC/SB
Mods - Spartan tuned via laptop, 4" AFE stainless exhaust system, 2.5" PMF BMC leveling spacers, 3" PMF lift blocks, Fox Racing 2.0 shocks, Recon smoked mirror & cab lights
08stroker250 is offline
post #4 of 10 Old 04-11-2013, 05:17 AM
LMAO.....First you think its the fuel filters, then tell everyone to buy traction bars now its the fuel pumps.... Its the damn tune....
Bellyboat is offline
post #5 of 10 Old 04-11-2013, 05:27 AM
Fuel filters could be the issue if they haven't been changed when needed. Traction bars help because axle wrap enhances the bucking. And yes, Eric from Innovative found that an issue related to some trucks and the low pressure fuel system can cause this issue. I know he posted it on PSN once, so I'm sure a quick search would find the post. Others have pointed to the pressure control valve in the HPFP as being the cause. There are many theories, which makes it hard to diagnose.
You're the expert here though, so I'm sure everyone will take your well thought out advice and run with it.
Jeff Dodd
post #6 of 10 Old 04-11-2013, 05:51 AM Thread Starter
All I know is it only does it on the 210t tune and I have had a year and 5 months since I noticed. I understand axlewrap could enhance an issue but if there wasn't an issue in the first place that would be ideal. New fuel filters don't help. Tried it.
100% stock
Spartan tuned
20' XD Hoss's
325/60 Duratracs
Leveled
chinaman is offline
post #7 of 10 Old 04-11-2013, 06:17 PM
So that's the only tune that does it or the only tune you have ran? I assume if that's the only tune you're seeing the issue with, it's only happening while your towing?
Jeff Dodd
post #8 of 10 Old 04-11-2013, 06:37 PM Thread Starter
Over the past year I have tried all types of combinations to include towing on other various tunes in the same speed range. Running the 210t empty etc.
He truck needs to have a moderate amount of resistance ie. 10000lbs on a small maybe 2 or3 percent grade. Same load on flat wont do it. Boost is therfore in the 30+range. its not as I am accelerating through the speed it does it but more of a holding steady speed on a small climb it will start. I have attempted to duplicate in other tunes and cant get it to do it.
I do notice frp jumps around on a larger range than normal. Normally its plus or minus a few hundred. While bucking it will be plus or minus maybe 1000.
When were the latest updates?
100% stock
Spartan tuned
20' XD Hoss's
325/60 Duratracs
Leveled
chinaman is offline
post #9 of 10 Old 04-11-2013, 06:38 PM Thread Starter
As always, Jeff, thanks for seemingly hunting out threads that apply to you guys. You are always more than helpful.
100% stock
Spartan tuned
20' XD Hoss's
325/60 Duratracs
Leveled
chinaman is offline
post #10 of 10 Old 04-12-2013, 03:35 PM
The last tuning files update was November 2011.
I would like to know what VGT duty cycle is doing while this is occurring.
Jeff Dodd
